Ford edge brakes |
bobkyllo
Joined: 14 Sep 2009 Location: minnesota Points: 1578 |
Topic: Ford edge brakesPosted: 12 Oct 2026 at 3:04am |
Hey guys wondering if you've ever run into something like i did this weekend.
2013 ford edge. Brakes worked great right at first but if you held them say your at a stop sign they would steadily sink to the floor and the brake holding power would go away. Must be a bad master cylinder. Removed it which was a chore on its own. Got new master and bench bleed it with block off plugs where the lines would go. Put it together and absolutely no brakes at all. Dad comes to help and he suggested to bleed the master the old school ways with lines going from the ports back into the resvoir. Put it all together and still nothing. Crack the lines loose at the master and use my power bleeder. Seems good. Went around to each wheel and power bled them. Still nothing. Had dad in the car pumped it up 3 times cracked each master cylinder line. No help. Dad asked about the abs. So we did a power bleed of that using a scan tool. We then finished the night with the pump 3 times hold and I Crack the line. None of this helped. I have no brakes at all. What could I have done wrong. I stared with a vehicle that I would be comfy going 80 in and stopping. I wouldn't have felt comfy depending on then holding after an extended period time of holding the pedal but at least it was drivable. I'm at the point I wouldn't take this over 2 miles per hour. |
john2189
Joined: 11 Sep 2009 Location: Minerva,Ohio Points: 468 |
Posted: 12 Oct 2026 at 5:26am |
Vacuum brake booster or hose bad?
Edited by john2189 - 12 Oct 2026 at 5:27am |
'41 Allis B
'49 Farmall Cub |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25505 |
Posted: 12 Oct 2026 at 6:19am |
hmm, if you can pump the brake pedal 3-4 times , pedals high, hold, then slowly goes down tot he floor, I'd say BAD rubbers in the master cylinder. It's feeding back ,around the 'loose' rubber from the outgoing side back into the reservoir side. I had that happen on my '57 Willys. pro brake shop ( #1 in Hamilton ) rebuilt the master cylinder, dang near killed me going down a steep hill.... anyway went to local parts store bought a NEW unit with 1/4" of dust on it.... worked 100%. hint.... if you have ZERO leaks..the oil HAS to be going 'somewhere'..round and round the rubber , is my best guess. |
bobkyllo
Posted: 12 Oct 2026 at 8:07am |
Ì also thought the new master cylinder was bad. So i went and got another one with no luck
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12514 |
Posted: 12 Oct 2026 at 8:19am |
This is crazy. I’m not any help at all but following. Because all I can think is that it’s gotta be something really stupid! Please keep us posted!!!
Joined: 11 Sep 2009 Location: illinois Points: 93341 |
Posted: 12 Oct 2026 at 9:16am |
Seems like you have eliminated the master cyl and the trapped air..........
--------- What Causes a Complete Loss of Brake Power? If your brake pedal drops straight to the floor or you lose all stopping power, the problem is not a bad ABS. A total loss of brakes is usually caused by:
Posted: 12 Oct 2026 at 9:20am |
Maybe pull the ABS fuse and then test it... When you start the car, the ELECTRICIAL to the ABS is ON.. When you are pumping the pedal with engine off, NO ABS..
----------- Yes, the ABS (Anti-lock Braking System) valves in a car are electrically controlled, even though they manage hydraulic brake fluid. How It Works
Edited by steve(ill) - 12 Oct 2026 at 9:20am |
bobkyllo
Posted: 12 Oct 2026 at 10:39am |
One other thing that comes to mind.
Push rod length? Is it possible that could be off so far to give me this trouble? Seems odd that 2 cylinders would both be that far out of adjustment. I. Haven't adjusted a push rod in ages. I will give the fuse a try. I just hate to give up but it gets to a point how much time can I afford to put into this |
Posted: 12 Oct 2026 at 1:36pm |
master cylinder and trapped air are both "old school problems"... normally an easy fix... thats why i suggest looking more into the ABS... it can have more Hidden problems.. and you apparently had some problem BEFORE you changed the Master. ... but checking the rod stroke is a good idea.. should be able to compare the OLD master to the NEW if you still have it..
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 5016 |
Posted: 11 hours 32 minutes ago at 2:29pm |
Niegbhor had 72 Chev C20 4x4 truck, the first year with front disc brakes. Somewhere around 2000 he was replacing rotors and pads on the front brakes as I stopped to visit about something. Complaining about the how hard they were to bleed. So he had gotten a power bleeder. Not many years later he retired, I bought the old pickup. A few more years go by one of the rubber brake lines breaks. I was having trouble getting the air out. Called my friend that just has touch with repairs, always goes faster with his help. Just has much better mechanics brain than I do. He takes one look, why do you have the bleeder valve on bottom? Never entered my mind to thing about. On that truck brake assembly fits ether side, but the bleeder hole are only drilled on one, so right and left are different. Some how the by now dead previous owner had gotten them bleed and they worked for years. But much easier to work with the earths forces and let air rise to eascape.
Maybe something you're not thinking of like me as you stare at it. I have never gotten into the ABS stuff. Please come with answer when it is fixed.
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 11102 |
Posted: 7 hours 37 minutes ago at 6:24pm |
My sisters Edge did that. Turned out to be the ABS solenoid. Like to never found one. I think just shy of a thousand dollars complete.
Posted: 7 hours 26 minutes ago at 6:35pm |
yea, i thought to pull the fuse and turn the ABS OFF... but if the valve failed in the wrong position and leaks thru... that might not work..
