Ford 10spd Transmission
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Topic: Ford 10spd Transmission
    Posted: 12 hours 38 minutes ago at 8:04am
Buddy of mine has a 2019 F-150 w/Eco-Boost 3.5ltr engine and 10 spd trans that is beginning to give him fits. Shaking, binding, sluggish action more frequently than in the past. Engine oil changes every 5K, transmission oil and filter Bi-annually with both services performed at the local Ford dealer. He asked me to look at it and I've read enough, and know enough people with this transmission and it's characteristics to know what he's in for.
There are product redesigns, software revisions, driver adaptability algorithms updates, (software) and Ford is involved in class action lawsuits over this transmission.
Here is a small blurb I found on the internet that explains just a few flaws folks are experiencing with this transmission series:
That's All Folks!
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 29 minutes ago at 8:13am
   Same tranny as GM but the valve bodies are different, both have issues with valve bodies.
    Next Gen Drivetrain makes kits and rebuilt valve bodies.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 28 minutes ago at 8:14am
would that be the same 10 speed that was developed in conjunction with GM (allegedly)? The same 10 speed that GM was marketing under the Allison trademark that Allison is now taking legal action against GM for?
well, I see NG beat me to it by 50 seconds!
Edited by LouSWPA - 12 hours 24 minutes ago at 8:18am
I am still confident of this;
Wait for the Lord;
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 59 minutes ago at 8:43am
It is the same basic trans as the gm.  They are junk.  Being run in school buses as well and failing with less than 10k on them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 48 minutes ago at 8:54am
Sad part is we have the tech, material, and brain power to produce a tranny that would take on all comers, fit many applications and live a long life. Just no money in it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 19 minutes ago at 1:23pm
Today's vehicles are the same as modern medicine/big pharma. They don't want to cure anything, just keep you alive enough to keep you coming back.
  I'll keep my 40+ year old vehicles going long enough to out last me and that's all I'll need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 11 minutes ago at 1:31pm
Both the Ford 5R110, and 6R140 seem to be very good and reliable transmissions. They probably should have stayed with that platform.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 56 minutes ago at 1:46pm
More Gears to spread the narrow Borderline Minimal Capability Engines curves into, to make what should not be in there functional somewhat, Nope, will stick with my Old Junk before go to one of these.  May as well have used a Infinitely variable trans as the Asians do.
Edited by DMiller - 6 hours 55 minutes ago at 1:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 5 minutes ago at 5:37pm
   You can blame the EPA, the 10 speed  is all about fuel economy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 26 minutes ago at 7:16pm
Yes, and it does actually work to keep the engine in it's highest torque range. It is the reason heavy trucks with automatic transmissions shift the way they do. Not very fast this way, but efficiency is highest.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 1 minutes ago at 7:41pm
i have a 6R80 6 speed in a 2013 F150... seems to work GREAT...100K miles... but i have heard that some have had trouble with the trans solenoids / wire harness at the PLUG on the trans..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 14 minutes ago at 8:28pm
That same site had a writeup on that trans also. Less problematic than the 10spd and IIRC the valve body was the largest culprit.
That's All Folks!
