Engine Serial Number
Puryear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Puryear Quote  Post ReplyReply Direct Link To This Post Topic: Engine Serial Number
    Posted: 22 Sep 2016 at 5:48pm
I bought a WD45 and the engine has been changed out with either a WD or WC engine. The serial number on the engine the best I can tell says W161508G. Can someone please tell me if this engine is from a WD or WC and what year. Also, did the WD and WC have the same type engines? Thanks a lot for any help y'all.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2016 at 6:51pm
The WD45 engine doesn't have the cover plate on the right side of ther block that the WC and WD engines have.
The WD 45 crankshaft, rods and pistons can be put into a WD block to nearly make a WD45 engine.
Gerald J.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2016 at 8:04pm
I'm thinking you have a 1946 WC block.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Puryear Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2016 at 8:34pm
Thanks, I was thinking the same thing but wanted to hear it from someone else to verify it.
This page was generated in 0.058 seconds.
