Dualling up a WD
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Topic: Dualling up a WD
    Posted: 16 May 2017 at 3:26pm
I swear I've seen some pictures around of WDs with duals. How do you put duals on spin out rims? Or do you change rims?
The mechanic always wins.
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 4:56pm
Had duals on 185 power adjust, clamps that go onto the rails and then straps to the duals. Have seen other but a similar way of doing it.
bobkyllo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 4:59pm
Take off one of the nuts on each of the rail clamps and replace with the clamp eyes. Then your band dual rim will need to have slots cut in them for the rails to fit into. Then just bolt up like you would normal. Very simple no special clamps needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 5:22pm
Anybody got any pictures? Do you fill them with fluid for traction, or just air for flotation?  I know from garden tractor duals you run half pressure on the duals.
We may as well turn this into  "Duals for Dummies"  (me). I don't know what normal is because I've never put duals on a full size tractor.
Now garden tractors on the other hand....
wiplowboy should recognize this one....
Edited by littlemarv - 16 May 2017 at 8:14pm
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 9:23pm
This is the WD45 I got at an auction sale a little over a month ago.  It came with the duals on it (and it does not look like they have been touched in years).  The tractor does have the original spin out rims on the inside.  It appears the duals hook to the inside lip on the wheel centers.  I do not know much more than that so far.
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 10:04pm
On 38s I put 14psi on inner and 12psi outer. I would think that should work on 28 as well
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 10:52pm
marv- i will send you a shot of mine' on the 45' i sent you a few days age' i will take a close up' there ac rims+ac hook up 13.6x28 tires
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 11:05pm
My wd45 uses clamps on the rails that are bolted on.
                  wd45and10footdisc003_zps5c5fc841.JPGwd45and10footdisc003_zps5c5fc841_2017-05-16_23-04-55.JPG
Edited by Don(MO) - 16 May 2017 at 11:08pm
Gary in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 4:34am
This is what the books show.
Bret (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bret (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 5:16am
We ran duals on the 45 we had on the farm when I was young.  They were just a second set of 45 wheel assemblies turned with the dish in and bolted on with the same lug bolts that hold the wheel assembly to the axle stub (longer bolts were used).  All 4 tires were loaded and all 4 had the same tread pattern.  We had an E III gleaner engine kit in it with a D-17 governor spring, and its main job was pulling a 10 ft. 1200 series field cultivator with a drag harrow behind that.
Edited by Bret (OH) - 17 May 2017 at 5:18am
