Difference in axle widths in B and C's |
OhKen
Topic: Difference in axle widths in B and C'sPosted: 18 Sep 2016 at 7:59pm |
We have an early B that has the tapered keyed axle , early B with foot brakes . My son just purchased a C that has a lot wider stance in the rear end . When did Allis switch to the wider rear ends ? My son wants to make a lowered B and had purchased this later model C to be the starting assembly , but the wide rear end is going to be a deal breaker . Did Allis offer a wide and narrow axle ?
Mrgoodwrench
Joined: 03 Apr 2011 Location: CHICORA PA Points: 2095 |
Posted: 18 Sep 2016 at 8:03pm |
The c is a wider "2 row" tractor a lot of parts are the same but c's are wider than b's. All c's are narrow front all b's are wide front
Joined: 11 Sep 2009 Location: illinois Points: 89106 |
Posted: 18 Sep 2016 at 8:08pm |
they use the same radiator, motor, clutch, transmission, and bevel gear case... The "C" has 6 inch wider final drive cases and axle shaft on each side, so 12 inches wider overall... and the "C" axles have 5 bolt ends and hubs bolt on like a car... the "B" has the tapered 2 inch bull axle end as you said. You can put any of the components on either tractor if you want. The wide finals will fit on the B and the narrow will fit on the C.. not the internal parts, but the complete case assembly.
Ken in Texas
Joined: 11 Sep 2009 Location: Henderson, TX Points: 5919 |
Posted: 18 Sep 2016 at 8:25pm |
Correction Mr Goodwrench Cs were built new with single front wheels and adjustable wide front axles beside the narrow front, it being the most popular.
And Steve knows Bs also came new with flanged rear axles and C 5 bolt wheels. C axles and B flanged axles do not interchange. Some early Bs with adjustable front axles were equipped with a 5 stud splined adapter hub and reversible Semi Dished rear wheels with the same 5 hole pattern as a C wheel. Adapter hub allowed early Bs with fixed rear tread to have adjustable rear tread widths. C wheels on Bs are also reversible making them quite wide tread for a B. You also have minor tread width options by reversing rims and by mounting rim clamps inside or outside the wheel disk. Edited by Ken in Texas - 18 Sep 2016 at 8:32pm |
OhKen
Posted: 18 Sep 2016 at 8:53pm |
The tractor was originally a C , we are pretty confident of that . The nose of the tractor has the cut out for the C steering shaft coming out of the narrow spindle housing . We want to make the tractor into a dropped tractor . I was not aware that C's were wider than B's in the rear end . Years ago and I mean decades , I had a C that we put a B front end on and I do not remember the C having a wider stance . Next question is what is the front axle off of ? It is adjustable . Was an adjustibale axle an option on B's and C's prior to CA's . And my final question does the axle have any value ? We have a B wishbone axle to turn upside down for the drop conversion . We just don't think it will work with this wide stance in the back .
Ken in Texas
Posted: 18 Sep 2016 at 9:05pm |
Yes Adjustable front axels were available on B as early as 1939 with the Adjustable Arched wishbone. In 1940 the adjustable straight tall spindle front axle in the narrow 38" to 60"wide version followed later by the same design in the wider 40" to 65" tread widths.
A good C adjustable front axle complete assembly should be worth at least $250 BTW. Not exactly the same as a CA adjustable wide front when looked at close. Edited by Ken in Texas - 07 Nov 2021 at 2:03pm |
Ken in Texas
Posted: 18 Sep 2016 at 9:13pm |
A slammed B would make a cool cruise-nite rat rod.
Edited by Ken in Texas - 18 Sep 2016 at 9:14pm |
OhKen
Posted: 18 Sep 2016 at 9:57pm |
That's my sons thinking also , but even with the rims set in as far as we can , the axle will be protruding past the tire sidewalls . Just don't think these axle assembly's are going to look rite . So there is a yard that has a considerable amount of B's and C's that we use and I'm pretty sure that they will have what we need . We want the newer axle with studs/bolts instead of the tapered axle with the nut . I should be looking for a later model B to accomplish this , agreed ?
Ken in Texas
Posted: 19 Sep 2016 at 5:54am |
Something 1950 B and up with C deep dish wheels should work for you. Like I stated above you also have the option between the deep dish C style wheel and the semi dished almost flat early B 5 bolt reversible wheel. A little harder to find than C wheels but I have a pair of the semi dished B wheels only available. Edited by Ken in Texas - 19 Sep 2016 at 6:02am |
Dakota Dave
Posted: 19 Sep 2016 at 9:41am |
the C axles with a deep dished wheel and rim in the innermost position can be got down to a 60" tread width and a wish bone B axle with the wheels dished out can be a 60" tread width. The B adjustable straight axle is considerably different than a C or CA adjustable axle. The B never had a front bolster so No Trike front was available.
rpropst
Posted: 19 Sep 2016 at 10:30am |
I could be wrong but you should be able to switch the output shafts from the C final drives to your B final drives and then use the B final drives for the project. I have switched the flanged output shaft from an adjustable axel B and a splined shaft from a standard B
. The shafts are the same on the inside.
1950 snap coupler B 1948 WD 1951Ca 1952B 1952adjustable axel B
Dakota Dave
Posted: 19 Sep 2016 at 12:08pm |
You can change the B finals but the C uses a different size bearings so you cant swap them. you can swap the complete final since they both bolt to the transmition.
Posted: 19 Sep 2016 at 1:47pm |
YEs, you can changed the B flanged output axle with a B splined output axle.. You can not change internal parts with the C final drive. The C output axle will not interchanged....... speaking of the B flanged axle, there are SOME around, but the tapered spline is much more common. Not impossible to find, but pretty rare in most parts of the country.
Ken in Texas
Posted: 19 Sep 2016 at 5:30pm |
Pretty Rare mainly because only 5300 or so Bs with the possibility of having flanged axles were built after 1952. From 47 to 1951 nearly 34000 Bs were built. Exactly how many of those Bs had flanged axles is almost impossible to calculate.
Posted: 19 Sep 2016 at 8:21pm |
Ken, do you see many in Texas ? I wonder if they were more popular in certain areas of the country.. IM sure there are some in the mid west, but looking at used for sale the past 15 years, about all I see is the splined rear with wishbone front end .... I have several Bs, of course most of mine are pre 1948 also !
wfmurray
Joined: 13 Sep 2009 Location: Bostic NC Points: 1225 |
Posted: 19 Sep 2016 at 8:32pm |
I have a 49 with flange and adj front axle.
Ken in Texas
Posted: 19 Sep 2016 at 8:42pm |
My kids 50B has the 5 stud flanged axle
Ken in Texas
Posted: 19 Sep 2016 at 8:52pm |
Where did Ohio Ken go? We were having a debate about swapping a B adjustable for a C adjustable or vice versa
OhKen
Posted: 19 Sep 2016 at 10:40pm |
I will try to post pics tomorrow of the adjustable front axle and the serial number of the tractor . This tractor also has a magneto and a coil , which makes me scratch my head . Tomorrow guys I promise .
Nathan (SD)
Joined: 11 Sep 2009 Location: Day County SD Points: 1286 |
Posted: 21 Sep 2016 at 11:10am |
CTuckerNWIL
Posted: 21 Sep 2016 at 3:56pm |
The old internal coils in the mags had a tendency to heat up and melt the insulation in them letting things short out. If the coil went bad, you could rig it with an external coil , making it into a distributor. |
Posted: 21 Sep 2016 at 4:12pm |
Nathans picture above shows the B 2 inch splined shaft on the left. The C 5 bolt shaft is on the right , and the B 5 bolt shaft is in the center Note that the LEFT and CENTER shafts are interchangeable in the B case.. The RIGHT shaft from the C has different locations for the bearings and seal...(further apart)... it will not interchange with the B ... unless you do some fancy lathe work....... the spline ends at the bottom of the photo are for the internal bull gear.
Posted: 21 Sep 2016 at 4:20pm |
Ken, is there a reason the B 5 bolt hub sticks out so far ? I have wondered about sleeving the C shaft and turning it to fit the oil seal... then building up the original shaft a few thousands to fit the outboard bearing. The hub would set in an inch or more compared to the B position. Is there a dirt shield or something on the back of the hub that would need reworked ? Or a C hub might be better ?
Dakota Dave
Posted: 21 Sep 2016 at 4:41pm |
The C wheels have a lot of dish. if you could bolt them up tight to the housing like a B flat wheel they would be touching the fenders. the greater dish was to enable a larger range of tread width adjustability.
Edited by Dakota Dave - 21 Sep 2016 at 4:44pm |
Ken in Texas
Posted: 21 Sep 2016 at 7:26pm |
I wish the picture of the three axles included the forth which would be the B axle stub on the left with the 5 stud B Hub adapter in place. They ran on a B using a almost flat semi dished 5 hole B wheel.
I have several sets of B axles and matching Splined Adapter Hubs. Near all have bad splines. Been seriously thinking of welding the hub to the axle and hiding the modification with the big axle nut. These welded up parts should be very similar to the B flanged axle pictured in the center with a little less tread width when installed. I have the 5 hole semi dish B wheels too. They actually have the same bolt pattern as a C or a B with the flanged axles Edited by Ken in Texas - 21 Sep 2016 at 7:30pm |
OhKen
Posted: 22 Sep 2016 at 8:58am |
Did the pics I tried to send you get thru ?
Ken in Texas
Posted: 22 Sep 2016 at 1:48pm |
You have mail
shameless (ne)
Joined: 08 Jul 2016 Location: nebraska Points: 7463 |
Posted: 22 Sep 2016 at 2:06pm |
we had a "C" with a wide front
BrianC
Joined: 16 Jun 2011 Location: New York Points: 1619 |
Posted: 22 Sep 2016 at 7:50pm |
On the B, the straight adjustable front was available in 1940 Ken says.
Which year was the last for ordering a B with the arched front end? Thanks |
Posted: 22 Sep 2016 at 7:57pm |
I though the arched axle was standard equipment from early 1940s up until the end in 1958 ? You could order other as an OPTION.
