Diesel additives
Rusty Allis View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rusty Allis Quote  Post ReplyReply Direct Link To This Post Topic: Diesel additives
    Posted: 1 hour 34 minutes ago at 10:50am
Group! Looking for some advice on diesel fuel additives I have some older (80's-90's) equipment (tractors, skid steers etc) that get mostly put up for winter in an unheated building.
Last year we had one that when getting it ready in spring started/stalled wouldn't restart and when it finally did, wouldn't rev. After some heat and gentle taps on the IP it came around and has been fine all season.
This has never happened in the past 15 years. It was a cold, miserable long winter here in the Northeast
We've run some ATF every few fill ups, but is there a good product anyone can suggest to "pickle" these old girls for the winter? Just trying to avoid another spring fiasco because of course, it's always "I needed it yesterday" when it comes time to recommission the stuff for the season
Thanks!
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 4 minutes ago at 12:20pm
I use Power Service, and usually have at least one tractor that I run through the cold weather. I have got to the point that I decided it is easier to just treat the fuel as we get it delivered instead of worrying about remembering to get everything treated in the fall. If you don't run the equipment when it is cold you shouldn't have to worry about getting it treated properly, but you need to read the label if you plan on using the equipment. There are different levels of treatment for different temperatures, and it is recommended to double the treatment if there is any percentage of biofuel. Depending on how much fuel you go through you may also want to add an anti algae product. Water is used in the refining process for diesel now, so you always have a chance of having some moisture in your fuel, part of the reason I have started using fuel treatment year round.
Ted
190XTD seriesIII, 190XTD seriesI, maroon belly 7000, 7030, 7045, D14, 190XTD series??? project(or maybe parts)
This page was generated in 0.168 seconds.
