D-17 water pump question |
lucky ![]() Bronze Level ![]() Joined: 02 Oct 2011 Location: United States Points: 38 |
![]() ![]() ![]() ![]() ![]() Posted: 20 May 2012 at 9:11pm |
Noticed a leak on the front of the pump and grabbed the fan / pulley and it wobbles.
Are they rebuildable? It still runs cool and doesn't leak too bad but needs fixed. Noticed on ebay they were upwards of 100 bucks. I don't mind repairing it if possible, but will more than likely involve a bearing of some sort?? Any feeback on what i'm up against here is appreciated. Thanks, Chris
Pat the Plumber CIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Springfield,Il Points: 4930 |
Several vendors on here re-build them or can sell a rebuild kit. I am sure 1 of them will chime in .Steve in NJ comes to mind
1964 D-17 SIV 3 Pt.WF,1964 D-15 Ser II 3pt.WF ,1960 D-17 SI NF,1956 WD 45 WF. |
JimD ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mounds, OK Points: 2116 |
You will have a hard time finding a rebuild kit. New is a lot easier, and I'll bet cheaper in the end.
JimD
Owner of OKtractor.com PM for an instant response on parts. Open M-F 9-6 Central.
We have new and used parts. 877-378-6543 |
I'm betting your'e right on that. The way it wobbles the bearing probably did enough damage to the race for me to handle it. That wouldn't mess up the core value would it?
Orange Blood ![]() Orange Level ![]() ![]() Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
I don't know of any vendor that wants the core anyhow, but I may be wrong.
Still in use:
79fordblake ![]() Orange Level ![]() Joined: 01 Jul 2010 Location: West Kentucky Points: 829 |
When the one on my WD45 started leaking I went with a new unit. Sometimes they will give you trouble when trying to rebuild them yourself...clearances have to be just right.
GregLawlerMinn ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
Rebuilding a waterpump is a risky affair for most mechanics. Have had better luck with new/re-man ones. Jim D (OK Tractor), Tony C (Tonys Tractors), Steve in NJ, and Sandy Lake Implement all are great folks and can get you a good replacement.
Currently have: 1 D14 and a D15S2. With new owners: 2Bs,9CAs,1WD,2 D12s,5D14s,3D15S2s, 2D17SIVs,D17D,1D19D;1 Unstyled WC |
Nathan (SD) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Day County SD Points: 1278 |
Usually the impellers are so corroded that they don't survive removal no matter how careful you are.
