D-15 Series II 3rd gear & Clutch |
coastga
Topic: D-15 Series II 3rd gear & ClutchPosted: 06 Jul 2023 at 3:52pm |
3rd gear went out on my D-15 several years ago and it took me two years to find a mechanic willing to jump on the problem. Man, was this an expensive proposition! Using all AGCO parts, the mechanic said, "You have more in the repair than the tractor is worth". A new heavy duty clutch was a whopping $800 not including the mechanic fee. The old China made clutch that I put in several years ago lasted only about 200 hours and that is with me not riding the clutch.
Edited by coastga - 07 Jul 2023 at 8:48am |
EPALLIS
Joined: 12 Sep 2009 Location: Illinois Points: 1171 |
Posted: 06 Jul 2023 at 3:58pm |
The price may have been steep. However, there are many people out there that are so grateful for your efforts. They don't make D-15's anymore and they are an amazing tractor. Just like planting a tree for the next generation you saved another A-C for the next generation. Much appreciated!
JimIA
Joined: 12 Sep 2009 Location: Castalia Iowa Points: 1991 |
Posted: 06 Jul 2023 at 6:28pm |
Did you look into a remanufactured clutch from Hy Capacity?
I have heard of people rewelding the gears if they are worn from grinding and jump out of gear but it takes a good welder to do it properly. Not sure if that is an option for you? As far as the repair costs, thats up to you. I can tell you that if you were to buy a new tractor that can do what a D15 can do it will cost you well over $30k. Years ago everyone were junking other tractors because of high cost repairs but fixing the green ones "because a JD was worth the repair". Just goes to show that JD are brilliant marketers. One thing that does worry me a bit is that tractor is being held up by the frame rails. I would prefer to hook it into the valve cover bolts. I dont think that front plate is built well enough to hold the engine up. I could be wrong but not the way I was taught to split a D series. Jim
coastga
Posted: 07 Jul 2023 at 8:44am |
I purchased the parts from Sandy Lake Implements. I told Brenda that I wanted a good clutch and purchased the clutch that she recommended.
