d-15 injection pump
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Topic: d-15 injection pump
    Posted: 04 Jun 2017 at 3:54pm
i have a 615 back hoe  going down the road it runs fine and then chugs like its out of fuel it dies i wait a min and restarts runs fine black smoke when goosed runs a mile and does the same thing.  i use to think fuel obstruction and not im wondering if its the electric solonoid in the pump maybe getting hot?  any ideas and whats the fix? cost for a new solonoid?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2017 at 6:58pm
Likely the lift section of the pump is wearing out.  Try putting an electric fuel pump between the tank and filters...
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2017 at 7:53pm
The D15 fuel filters are located on the side of the battery box which is about half way up fuel tank. They are prone to trap air because of their position. Pull bleed plug out of top of filters. I just blow in the tank till fuel comes out. Put plug in and all should good.
FYI, a factory type non collapsible hose is necessary between filters and pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2017 at 8:12pm
ok thanks guys
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2017 at 9:24pm
Roosa pump? Flex ring seen better days?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2017 at 9:33pm
If it starts back up after it sets a minute it is the flexing in pump. Pieces is plugging the return fitting on pump.     MACK
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2017 at 10:14pm
Yep, return plugged up with broken flex ring particles.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2017 at 12:55am
much of a job to replace the flex ring or is it a complete tear down?/
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2017 at 7:23am
pump rebuild. knock out the return ball in the return fitting, and nurse it through the task at hand. When it can sit a little while, pull it off and send it in for rebuild.
