D15 diesel - getting fuel to the filters |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7732 |
Topic: D15 diesel - getting fuel to the filtersPosted: 01 Nov 2026 at 7:19am |
I have my series 2 diesel looking more stock than when I got it. However, I am not able to get fuel from the tank up into the filters. I have 1/4 tank of fuel and I have had new seals put in the hand primer, but I cannot get it to pull fuel up to the filters. The primer was tested separately and it does work. I do have a very small leak on the 90 coming out of the sediment bowl if that makes a difference. Would filling the tank full make a difference? ![]() |
Joined: 11 Sep 2009 Location: illinois Points: 93530 |
Posted: 01 Nov 2026 at 7:24am |
it should work at 1/4 tank, but if you look at that level compared to the filtes, the fuel level is only partialy up inside the filters.. a good test would be to fill the tank and test again... and YES.. any minor fuel leak can be a MAJOR air leak and cause loss of suction.
--------------------- this is WATER instead of FUEL... but gives you a good idea of a "MINOR LEAK"... How This Affects Flow Through a Crack
Edited by steve(ill) - 01 Nov 2026 at 7:29am |
Nathan (SD)
Joined: 11 Sep 2009 Location: Day County SD Points: 1328 |
Posted: 01 Nov 2026 at 10:01am |
If the tank was full, you could gravity bleed it and throw the primer away. Thats just me.
Jim.ME
Posted: 01 Nov 2026 at 11:20am |
Fix the leak for starters. Adding more fuel to the tank will give it more head pressure and it will leak more. A leak on the suction side of any pump is not a good thing.
Posted: 01 Nov 2026 at 3:04pm |
is that a factory setup with the primer pump stick out the top of the filter , way up in the air ?.... would have been a better design to have an elbow on top of the filter and put the primer at the side of the filter, or below.......... but fixing the LEAKING ELBOW might fix all your problem.
DSeries4
Posted: 01 Nov 2026 at 3:29pm |
That's how a series is 2 is supposed to be set up - wasn't like that when I bought the tractor.
Some have said it is not the greatest set up with the primer that high up, but given the space constraints around the sediment bowl, that's where it sits. I will top off the tank and fix the leak and it should be good. Thanks for the responses. |
Acdiesel
Joined: 15 Jun 2012 Location: Rochester Ohio Points: 2602 |
Posted: 2 hours 58 minutes ago at 10:48am |
mine does not have the adaptors before and after the hand primer, which shouldn't matter, fuel just has to go up that much higher before it goes down. as others said fix the leaks and see what happens. You can also put a little air pressure in the fuel tank to get it primed. Edited by Acdiesel - 2 hours 56 minutes ago at 10:50am |
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF D15 SER.2 DIESEL D12 SER.I, D10 Ser.II 2-720'S D21 Ser. II Gmc,caterpillar I'm a pharmacist (farm assist) with a PHD (post hole digger) |
