D-14 ring gear
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: D-14 ring gear
    Posted: 16 Mar 2012 at 8:36pm
Ok, got my new D-14 ring gear in from 'local' AGCO shop, yeah the 'oddball' 93 tooth one.....$75 for them, 12 for shipping, rest in taxes.
Checked to be sure it was the right one ,looked ok....least it HAS 93 GOOD teeth  !
Went to toss the packing into the fire, read the label..
AGCO.........MADE in INDIA
WHAT ????? Anyone else heard of this !!!!
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 9:00pm
Be thankful that it is still available!!!!Wink
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 10:34pm
Where did  you think it was made!!!!!
OrangePowerFranzen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangePowerFranzen Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 11:36pm
well at least it isnt from China!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 9:14am
Silly me ,I'd have thought I'd be getting 'New Old Stock' as they must have made a whack of them...
Interesting that there's a market to make repo units.Must be a LOT of tractors(maybe cars) that use an 11" clutch and 10th Delco starter ??
NickT(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NickT(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 10:11pm
On my D-14 I just took the ring gear off and flipped it and rotated it 2 hrs. on the clock face. Works like a new one since the teeth the starter hits now are "new".
mherndon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mherndon Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2012 at 4:27pm
Is flipping the flywheel common? I was looking at ordering one, but wondered if they could be flipped.
Mark
D-15, Old dealer in Smithville, TN
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2012 at 5:49pm
Don't recommend flipping as the teeth are chamfered somewhat on the starter side and square on the back side. That said, know of several that were fipped and worked. Also know of several that were removed and rotated 90 degrees, was told that the engine normally stops at the same spot, or 180 degrees from it.
Seeing as how much is involved in splitting the tractor and the cost of a new ring gear, never could convince myself to try salvaging one and then having to redo the work if it did not work out right for me.
Edited by GregLawlerMinn - 20 May 2012 at 5:53pm
