D14 loader value
Frankenpez View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frankenpez Quote  Post ReplyReply Direct Link To This Post Topic: D14 loader value
    Posted: 30 May 2017 at 10:40pm
Hello, I'm looking at a D14 with an Allied 6' loader. Not wanting the loader, could someone give me an idea on the value of the loader? I'd like to sell it seperately should I buy the tractor. Then I can make an appropriate offer on the tractor.
Thanks in advance-
Jon
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2017 at 3:41am
Hi jon, were gonna need to know what kinda shape the loader is in and photo's help a lot. dt
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2017 at 6:32am
Maybe $500-$1000 depending on shape and leaks,assuming the front pump/bracket,hoses, frame ,etc. goes as a complete package.
I took off the 6' bucket on 'Milton' as it's too big for my use.
Does the D-14 have power steering ? It should when using a loader....
Check BOTH front rims real careful. Milton needed new ones as both had stress fractures near the bolt holes. I'm thinking a lot of turning while stopped with full loads caused them.
If the clutch pedal 'diamonds' are wore, it was used a LOT for loader operation, so maybe new clutch/bearings will be needed.
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frankenpez Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2017 at 9:59pm
https://siouxcity.craigslist.org/grd/6152599642.html
Craigslist
Hopefully this link works. Ideally I'd like to be in the tractor itself for $1500. At least thats my budget. Not sure if the loader is worth around $1000?
As you can see there's no pictures of the bucket unfortunately.
Thanks again for the help and opinions of this tractor.
