cylinder sleeves
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Topic: cylinder sleeves
    Posted: 09 Apr 2011 at 3:51pm
Ok, new sleeve should spin easily w/o o rings. New sleeves are binding at the bottom, i believe resulting from rusty scale build up on upper part of area where rings will seat. My question is, how does one clean that up w/o scaring the surface to the point that the rings would snag and be damaged on it?
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2011 at 3:54pm
I have used what is called a 'Huckleburr' hone one of those with the wire supported balls of abrasives, if the bore gets too torn up or the rust too deep it may require a counterbore re-sleeve.
One other note, use Crisco to lube the sleeve seal rings, they will not swell as they will with petroleum lubes.
Edited by DMiller - 09 Apr 2011 at 3:56pm
Michael Crowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2011 at 7:12pm
It also helps to put the new sleeves in the freezer over night, and then only take them out one at a time as you install them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2011 at 7:26pm
I've heard the type of hone DMiller is talking about also called a "rabbit turd" hone. I had to run one in the sleeve seal areas on my CA block when I overhauled it. On mine, I honed it until I could shove them in with some effort. I didn't hone them to the point they could be turned easily w/o the o rings. It's been like 15 years now since I went through it. Just finally decided to run the rack (valve lash) a while back. Only thing it's needed other than a reman dist in all that time.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2011 at 8:00pm
I use a dremel with small wire wheels and the sanding drum w/emory cylinders with good results. I also use olive oil to lube the O-rings.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2011 at 8:23pm
Thar she bee in a upper rite corner.
I also use a carbide burr for the tight spots where the flapper wheel seems to slow. You never hold it in one place. you rake around in a circle lightly. A flapper wheel will not scar.
I use a 1 1/4" wire wheel in the die grinder to clean the inside of the water jacket. One of them thar jobs that makes it hard to keep you nose hair clean.
Edited by Dick L - 09 Apr 2011 at 8:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2011 at 8:50pm
Lou, I did it the easy way. I put my block in a plastic 55 gallon barrel and cooked it with the battery charger for a week or 2. All the nasty rust is gone and a flapper wheel like Dick has will easily polish up the lead in. The next best thing, but costs money, is to have the block baked and shot blasted, or dipped and cleaned. Get rid of that flaky bubbly rust, then polish the chamfer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2011 at 8:58pm
The chamfered area would need to be clean and smooth for assembly, to keep o-rings from being snagged, but shouldn't bother the sleeves. If you clean a bore up with sand paper, then put a sleeve in and turn it, you might be able to detect a high spot on the bore. Some high spot bluing would make the interference show up. Maybe your sleeves are a tad out of round?? I would polish the bore and get a Micrometer and an inside mic or telescoping gauge and check roundness of both the sleeves and the bore.
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2011 at 10:46pm
Little chunks of emery cloth,thumbs,fingers and a fair bit of elbow grease not to mention time.
Larry Miller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Miller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2011 at 11:26pm
I use a piston ring groove cleaner to clean out the groove for the O rings. Just take  off the little wheel for different width grooves and scrape away - not fun or easy but it gets er done. You can feel the crud and when it is gone too.
I used to be young and stupid, now I am not young anymore.
