CONVERTING FROM NEIHOFF TO DELCO
SIMPLICITY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Topic: CONVERTING FROM NEIHOFF TO DELCO
    Posted: 04 Jun 2012 at 10:30pm
 HELLO
 I AM GOING TO CONVERT FROM A NEIHOFF TO A DELCO, AND SOMEONE SENT ME A MESSAGE THAT FOR THAT TO WORK I WILL NEED TO CHANGE THE PULLEY DIA.
   MY LOCAL ALT. REPAIR SHOP KINDA PULLED A FAST ONE ON ME, I TOLD HIM THAT I WANTED AN EST. FOR THE REPAIR CUZ I KNEW THAT NEIHOFF'S ARE EXPENSIVE TO REPAIR. WELL I DIDN'T GET A CALL TILL IT WAS READY, AND  OMG $597.00 I THOUGHT I WOULD LOOSE IT.  I TOLD HIM HE COULD KEEP IT, HE NEVER CALLED ME WITH A EST. SO DELCO HERE I COME. IF ANY BODY CAN HELP ME FIND A PULLEY IT WOULD BE DEEPLY APPRECIATED
 I AM NOT SURE BUT I THINK THE PULLEY NEEDS TO BE .650 ID AND 3 7/8 OD. THANKS THAD 337-937-6781
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2012 at 10:35pm
Most of the Delco will take a pulley off a generator as a direct fit. Check on size used on some heavy C series trucks as they used a smaller cast iron pulley.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2012 at 6:39am
Most Delco's use a .670 shaft. Been using that shaft for years. That's why I tell our customer's when doing a 6-12V conversion, to use the pulley off their Gennie and install onto their Alternator. Niehoff is an excellent unit, but will give you heart failure with the cost of repair parts alone. Depending on the application and amperage, some Bosch "AL" series Alternators are a nice replacement. Actually, they're a little tougher than the 21 or 22 SI series Delco's. I probably could help you out with a pulley if you knew what the Niehoff model # was that you had. We have bins full of pulleys. Obviously, someone wasn't listening when you said you wanted a quote....  Sheesh!
