Chisel plow question
mark-east-tn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark-east-tn Quote  Post ReplyReply Direct Link To This Post Topic: Chisel plow question
    Posted: 03 May 2018 at 9:14pm
I have a add in classifieds wanting to buy a chisel plow for my 8010 2wd tractor what size do you all recommend for ground in east tn. , would like to have pull type have a 3pt hitch type now that’s a 5 bottom but I need to go bigger . Thanks for input , chisel plows around me are not very common equipment .
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2018 at 10:19pm
7 shank if you put it in the ground. Pull a 9 shank with 7050.   MACK
Johnwilson_osf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnwilson_osf Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 6:54am
We pull an 11 shank 3pt chisel (IH model) with our 8010.  It pulls it well, depending upon conditions.
Allis Express: Eastern PA on Rt 80
8050, 8010, 6080, 190, D14, DA 6035, AA 6690, 5650, Gleaner F2
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 9:42am
An Allis Min-Til 9 shank is all my 7050 can handle if I put it in as deep as it will go in our ground. In fact without a lot of additional weight it won't pull it all the way in, but the 190XT pulls an old Krause 9 shank as deep as it will go all day long in 5th gear.
Wink
I am a Russian Bot
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 4:21pm
Josh in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 8:02pm
Are you looking for a disc chisel or just a pull type chisel plow? If your looking at disc chisel, I’d say 5 shank, and maybe 7. Drawn chisel plow, 7 shanks would probably work good.    They work best going fast.
Kurt WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurt WI Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 8:13pm
I have a 7 shank Landoll soil saver for sale. Pulled it with a 7020. Located in WI
WD D17D 170 190xt 190xtIII 200 7020
