Chain saw carburetor
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Topic: Chain saw carburetor
    Posted: 30 Apr 2025 at 1:18pm
Have a Stilh concrete saw that would start ONCE and run, but shut it off and it will FLOOD and not restart.. Got to pull the spark plug, drain cylinder, heat up the plug and reinstall.. Sure seems like needle gas valve is leaking thru or bad gasket. Took carb apart TWICE and check and could not determina a problme...... Ended up buying an aftermarket CARB on Amazon for $35. and install ........... problem SOLVED.
Counting two chain saws, this is the 3rd small gas engine that has been "FIXED" by buying an aftermarket carb for $20- 35. and installing !!!
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2025 at 1:36pm
Can buy the carb repair kit also , and it seems they fit many different carbs . Priced one for my Johnsered  601 and found lit fits 2 other saws I have . Price on e-bay was around $4 per kit , local saw repair shop wanted $20 for kit for 1 saw
"Challenges are what make life interesting; overcoming them is what makes life meaningful."
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2025 at 4:51pm
i was considering a gaskety kit... but i thought the gas inlet needle valve might be the problem ( no guarantee).. and i had GREAT results with two other CARBS that i bought...  almost a Guarantee fix..
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2025 at 9:41pm
I did the gasket kit on my 40 year old poulan still had problems. Couldnt get an ecavt carb so i got one gor a post hole dogger. It was on number off changed the throttle arm from my old carb started right up. Put an amazon carb on my husquvarna started 2nd pull a little teeeking and it runs perfect. Been 4 years since i replaced the carb rides in the back of my yruck st the farm always starts and runs great.
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 32 minutes ago at 10:04am
Yep, that is the only way to go now a days  Wink
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 8 minutes ago at 10:28am
That's the way I've been solving mine, Steve... with the caveat that when I take the original carb off, I put it (with any other removed rebuildable parts) into an oval-shaped plastic storage container strikingly similar to those found containing my favorite brand of Chocolate Almond  ice cream... Tongue
I haven't had a bad replacement carb YET... but at the price, I generally have two of each on my shelf.
The part that makes the most SENSE (and why the OEM doesn't see fit to replicate) is that when you buy one'a them carb kits, it comes with replacement fuel lines, filter, usually a spark plug and air filter.  The bar oiler pump, likewise, comes from the aftermarket in the form of a 'kit'.    Now, I don't put much faith in the spark plugs, but when I go through one of my saws, I disassemble, clean it all (including the muffler!!)  inspect the piston for scoring... then replace the carb and fuel lines, the oil line and pump, I scrub out the bar, flood the sprocket to rinse it out good, inspect it for damage, file off the burr, inspect the sprocket/clutch (replace it if necessary), then put it all back together with a new chain.
Darned few situations where I do all that, and DON'T have a good running, reliable saw for the season.  I've lost count of how many saws I have in my armory... probably a dozen... but they all get the same treatment.
I USED to use my saws until they'd have running problems, THEN tear them down.  I learned something really really amazing...
I found that they'd NEVER give me any kind of problems when I wasn't using them.  If they were on a shelf, sitting, they'd never flood or stall, they'd never have problems starting, or running... or oiling...  they'd just sit there, and wait patiently without a complaint...
But the very moment I took 'em out to tackle a task, I'd find problems...
   so I'd hafta stop what I was trying to do, and carry it back in, and go through it.Angry
So I started carrying TWO saws... that way, if one had a problem... I could determine wether it was from a bad batch of fuel (because the other one would suffer the same problem) or from some other situation... like a dulled blade... at which point, I'd stop what I was doing, and carry them BOTH in for a rehab.Disapprove
So I started carrying THREE saws... the first two for the aforementioned problem, and the third, because invariably I'd be cutting through something and the first saw would have running problems, the second would wind up with a dulled blade... so I could pull out a third saw that was ready-to-go, insert it into the same kerf, continue the cut, only to find out that it too, had an immediately dull blade.Stern Smile
Then I'd get a fourth saw, and stick it in there, just to make certain that the rock buried inside that tree really WAS tougher than my freshly-sharpened chain...Wacko
(is there a theme forming here?  LOL)
But really... I'll offer this advise to ANYONE...  If you want to be successful at accomplishing your tasks in a swift and efficient manner, accept my offer of experience... learn from MY mistakes!!!
Edited by DaveKamp - 14 hours 6 minutes ago at 10:30am
