Centering a Wheel |
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Topic: Centering a WheelPosted: 08 May 2019 at 1:56pm |
Last time I adjusted my wheels in (190 power shift rims) 1 side is not centered so I get the wheel out of center up and down going down the road
Easy way to center wheels? |
Charlie
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3672 |
Posted: 08 May 2019 at 2:47pm |
Yes that can be tricky. To get the power shift inner centers to rail in or out, it’s outer clamps require adequate loosening. So once you’ve move the inner center & it’s time to re-tighten their outer clamps, EVENLY tighten the 3 & 9 o’clock clamps ONLY first. Then, rotated the whole wheel 90 degrees. This places the tightened 3 & 9 clamps at 12 & 6 position? Trying to remember if 190 has 6 or 8 clamps? If only 6 clamps, then I guess 3 & 9 position would only rotate up to only 11 & 5 positions?? Once there, tighten the other 3 & 9 positions. Again, tighten them EVENLY. Continue tightening in that style.
Edited by AC7060IL - 08 May 2019 at 2:54pm |
randy
Joined: 12 Sep 2009 Location: Illinois Points: 1261 |
Posted: 08 May 2019 at 8:03pm |
I always had trouble with mine. Will have to remember that. I always started with the top and botton.
