CA head
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Topic: CA head
    Posted: 07 May 2019 at 8:46pm
Is the head on the C and CA the same?
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 1:20am
Yes: the head from a B or C is the same as. CA.
Jgranat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jgranat Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 4:06am
Are the carbs the same too?  Not to hijack, but it is also useful info for a C or CA owner.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 5:16am
Thanks Paul
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 5:28am
The carburetors have big differences from the early 1939 Bs to the 1957 CAs. Also both Zeniths and Marvel Sheblers were used with differences for dthe different fuels of the time. The B,C & CA tractors were available to run on gasoline and kerosene. The. B&Cs were also available to run on alcohol.
With all that the carburetors will bolt on accross all models wit the 116 and 125 engines.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 9:50am
The family shop manual may give some comparisons:
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
Gerald J.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 11:35am
Paul, I looked for the pictures of the difference in the older and newer heads that will inter change between any of those tractors. I found a difference when boring and porting them. I think you would be interested in the difference. I am not doing head work anymore but I have two at the factory I might take pictures for you.
