CA carburetor throttle shaft
Dean(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean(IA) Quote  Post ReplyReply Direct Link To This Post Topic: CA carburetor throttle shaft
    Posted: 02 Jul 2017 at 3:27pm
I am trying to fix a CA carburetor that is missing the throttle shaft lever.
Most of the kits say that they fit CA and D/10 D/12. The throttle shaft
in those kits is too long and hits the block.
Does anyone know of a vendor who has the kit with the correct throttle
shaft and lever for the CA?
Thanks,
Dean
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2017 at 4:07pm
DO you mean it bottoms out on the plug on the outside hole?
Larry in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2017 at 4:52pm
Do you have a Marvel Schebler or Zenith carburetor?  If you search for a kit for the carburetor number that you have you should be able to find the correct throttle.  The Marvel will have a plate on the throat of the carburetor and the number will start with TSX.  The Zenith number is on the round plate on top of the carburetor.
Jim-Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim-Ohio Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2017 at 9:00pm
I would call Steve at B & B Custom Circuits. His ad is on the Parts & Services page.
'61D17, '51WD, '51CA, '41C, '49C, Woods 5'&6'Mower, 6'Blade, CA-Plow, CA-Cultivator, 3-Btm snap-coupler plow, 4-row planter, WD 4-row cultivator, 80R mower,#7 mower,B/C mower
