CA axle clutch
Dave H (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H (NE) Quote  Post ReplyReply Direct Link To This Post Topic: CA axle clutch
    Posted: 29 Apr 2011 at 9:23pm
what holds the clutch in the final drive housing? and how do you guys remove it? thanks Dave
Wil M (NEIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wil M (NEIA) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2011 at 9:53pm
If I remember right, the final drive axle goes in one end and the axle that goes into the transmission.  You need to remove the brakes and the final drive housing off of the tractor.
Hope this helps
Wil
"Yet there are soulless men whose hand and brain tear down what time will never give again." Anderson M Scruggs
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2011 at 9:49am
All those I have done were held by a key on the outboard axle shaft (no set screw or clips, just slid onto the axle and half moon key). Most came out easily after the final was pulled off the tractor; some had to be "coxed" using pry bars thru the access hole in the final.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2011 at 7:22pm
thanks Greg that is what I needed to know. this one is stuck on the final drive
This page was generated in 0.035 seconds.
