Barrel stove
Walker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2025 at 5:08pm
Back in the 70s my neighbor sent away for a book with plans to build what they called either a HASHA or a hasha house. As I recall, it was a small block square more or less an outhouse looking thing out of cement block as big square or rect. as you want to cut logs.  Partially filled with sand while you added sand, you buried aluminum rods in it. I remember we were laughing about something at the time, and it seems to me it was because they left out transferring the heat to your house and a roof parts. That what I thought I was giving u when I said to google it up. Suppose to be all the rage in Switzerland or somewhere at the time.   I never heard of it again till now.
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2025 at 4:29am
I have another question.
I found a long section of stainless triple wall stove pipe with a roof boot and a cap. It’s in very nice used condition.
The barrel stove kit uses 6” pipe. Can I run the 6” up to the 8” without draft problems?
Would be somewhere around 4’ of 6” pipe then an adapter.
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2025 at 8:24am
Before cutting into your roof, can you set up the pipes you want to use with the stove outside and actually test it?
Use guy wires to hold the top of the pipe.
We used a wood stove in the house growing up and it was 6in round up and six ft to the wall and then the vertical rectangular block+brick chimney with larger cross section. So seems like you will be ok, but a test can prove it will work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2025 at 4:35am
It's ok to go smaller into larger on the chimney side, but I would do it close to the stove outlet and get the bennies of larger for more distance. If it starts burning hotter than you'd like, slow it with the draft. I really doubt if it will, but what do I know. First sentence is confusing, what I'm saying is keep it big from back of stove to top of chimney after it exits the stove.
Edited by Walker - 23 Dec 2025 at 4:41am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 35 minutes ago at 7:08pm
I’ve decided against the wood stove.
The price of double wall stove pipe is crazy expensive and the space this requires is ridiculous and the insurance guy would not go for this.
Now I’m on the hunt for something that takes up less real estate.
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 18 minutes ago at 11:25pm
Look at the Roger Sanders waste oil burner. Uses a water heater tank and a cone shaped burner pot. It is a drip system. with the cone shaped you can vary the heat output by varying the size of the puddle in the cone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 3 minutes ago at 5:40am
I’m afraid the insurance guy will frown on these or my homemade wood stove.
Not sure what I’m going to do yet?
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 48 minutes ago at 5:55am
We used a barrel stove for home heating for several years when I was growing up. Knowing my dad and looking back, it was “quite the setup”. Insurance never got involved thankfully.
Maybe 15 years ago or so dad was heating with a corn boiler. Thankfully it was located in a purpose built room for it, cement board and so forth. But he ended up with an outdoor unit crammed in that little room. Nowhere near enough space/ clearance to the walls. It had a hopper of corn directly above the fire box and it had a self starter that you connected a propane tank to. Not completely sure what happened but the working theory is that it got hot enough in there that the pressure relief on the propane discharged some propane which then flashed and caught the corn in the hopper on fire. Thankfully the door to the room was closed tight which frequently was not the case. Although might not have happened had it been flowing some heat into the garage. Anyway, burned all the electrical in the room, destroyed the controls on the unit, damaged the doors, smoke damage. Dad called the insurance man. He stood there, flipped a few pages on his clipboard, and said “It says here you have natural gas forced air heat” and left.
So yeah, you’re probably right to be concerned about what the insurance guy thinks.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 24 minutes ago at 7:19am
Have you considered an unvented propane or natural gas heater? They are thermostatically controlled, very efficient, reasonably priced, relatively easy to install and quite safe. Many are UL certified.
Edited by WF owner - 2 hours 23 minutes ago at 7:20am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 15 minutes ago at 7:28am
Exactly what I’m looking at. 👍
Sure wouldn’t take up much room.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 44 minutes ago at 7:59am
i would consider a small propane furnace for a house.. You get a 2 inch PVC inlet air and 2 inch PVC outlet chimney... The discharge is less than 100 degrees.. ALL the heat stays in the building and ALL the "smoke and fumes" go outside... some are 96% efficient ... standard is 80% or better.
Edited by steve(ill) - 1 hour 42 minutes ago at 8:01am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 minutes ago at 9:27am
Best can remember, had a Pad Poured with a Footer wall, Steel Studs for wall supports and Steel Truss.  The damper Fuse Links were available thru his local HVAC Guys, they made the ducting.  Used Waste oil into a existing Wood Burner Furnace, used Drip method with a loss of heat solenoid control to stop oil flow if fire went out.  Got pretty Complex until he sold the place off.
