Angry, At SELF, back into KW
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: Angry, At SELF, back into KW
    Posted: 1 hour 31 minutes ago at 2:16pm
So was washing the old Beast, found Right flat area of Hood and one spot on Left was Clear Degrading.  Was thinking was MY bad Paint Application, then heat spoke to me.  I had during Reman, removed the Self Destructing Under Hood heat and Noise Blanket, hanging in shreds and had doubts as to value to reinstall, got a price for a replacement Kit from KW, almost three years ago now, $1200.  All Precut pieces, Adhesive, Retention Pins and Washers, Epoxy to glue Pins to Hood underside.
So I am currently In Process to strip off Burnt up Clear, have likely enough Blue to touch up a few bad spots, then still have 1/3 gal of Clear to mix and blend cover to hood edge lines the Clear.  Called Kenworth dealer, Ordered Insulation Package, still ill over the price increase, now over $1800.  Will NOT be dealing with this again.
Then the Blinds Valances
Can see the Holes where remounted a Stop Shelf as the original was removed.
Edited by DMiller - 1 hour 12 minutes ago at 2:35pm
