Allis Chalmers B and C steering box
John426 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John426 Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers B and C steering box
    Posted: 04 Mar 2019 at 1:22pm
Hi
I have an Allis C , the steering box need to be replace, Does the stering box from model B and C are the same and interchangeables?
Thanks
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2019 at 1:25pm
No
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2019 at 4:51pm
Should be some information in the combined shop manual:
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2019 at 5:53pm
The Ross steering gearbox was used on B, C and CA models.
Post Options Post Options   Thanks (0) Thanks(0)   Quote John426 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2019 at 2:47am
Hi
I know that Ross made steering box for model B ,C, anf CA. But the question is, Does a steering box of a B or a CA fit a model C ?
Thanks
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2019 at 6:38am
They steer backwards of each other. The B arm goes down and the C arm goes up.  The case might be the same, but the gears are cut mirror to each other and won't work.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2019 at 7:48am
The steerings are unique to each tractor. The B is the smallest, the C is a little larger and tha one for the CA is completely different, it has 2 steering pins inside as opposed to only 1 fot the B&C.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2019 at 11:15am
The B Ross steering box has a shorter and smaller diameter cross shaft than the C. The C used both Ross and Gemmer steering boxes. The only CA steering boxes I have seen was Ross which had two palls rather than one. The C and CA would have the longer shaft. I am not sure if the arm to the steering link had the same spline. When I put the CA steering box on a C I used the arm that came with it and didn't check the fit of the C arm on the CA splines.
Edited by Dick L - 05 Mar 2019 at 11:16am
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2019 at 1:08pm
What is the better B steering?  The Ross or the Gemmer Box
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2019 at 2:06pm
My personal opinion is that the Gemmer is a better designed box, it has more adjustability to compensate for wear.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2019 at 2:23pm
Gemler box is probably better but more complicated and there are fewer of them around.
If you need parts that are No Longer Available ask as there are people making aftermarket parts and ther are some used parts around.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2019 at 4:18pm
I agree with the Gemmer being the better of the two. Of course that is just my opinion. I have at least two of the Gemmers. I noticed two complete boxes with steering wheels and tool box shroud and arms the other day in a parts pile. I would guess they were Ross boxes for B's. I know there is a Gemmer I took apart a few years back and put it somewhere.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2019 at 5:48pm
I'm a little sick since I scrapped 8 tons of Orange Iron.   I remember saving the Acorn Nuts off the Complete B/C steering assemblies that went on the trailer. With my luck I didn't save enough goodies.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2019 at 10:10am
I'd like to find a steering gear box, complete, got a D-10 series III.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote John426 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2019 at 3:43am
Hi
I found this pics on the web, Do you think it is a good idea to replace the steering of a C by the one of a B?
Is it working well ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2019 at 5:36am
Originally posted by John426 John426 wrote:
Hi
Hey, that is my narrow front B! I bought that from Roger VanCamp years ago as a factory narrow front B. He thought is was a rare tractor and had it for years. His son broke something on it and it set to the North of his barn for years and had set up. I tried for years to buy it and one day he said he would sell it to me if I would restore it and switch it over for starter. He loaded all the necessary parts along with the tractor.
I stripped it down and Roger was disappointed when I showed him the torque tube where the wide wishbone had wore into it before it had been changed to a narrow front. It had the C steering box on it and I used the B steering box and constructed a B steering arm to fit the C steering link.
The picture with the blue was the second paint job after I put a 4 inch stroke crankshaft in it and Chevy valves in the head.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2019 at 6:15am
Doesn't it steer backwards?
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2019 at 6:21am
AaronSEIA
No it does not steer backwards.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2019 at 6:32am
AaronSEIA
simple test to show why it would or wouldn't! Hold a pencil in the center and when you rotate it like the steering arm would move you will find one end will push forward as the bottom will pull backward.
In the picture on the trailer with the C the arm is up and the picture with the B steering box the arm is down. All that needs to be done is to have the steering arm on the box to push to make the wheels to go the correct way. If it steers backward just change the arm the opposite way on the shaft you have it and walla you solved the problem. If the sun is shinning bright and you can't see it look up instead of down.
It is called thinking about how things work when your making non factory changes. It makes things more fun with less road blocks.
Edited by Dick L - 26 Apr 2019 at 6:38am
This page was generated in 0.216 seconds.
