Allis C Engine - Getting Water in Oil |
gdtractor
Topic: Allis C Engine - Getting Water in OilPosted: 24 May 2017 at 1:07am |
Hi .. I am still getting water in oil with a new head gasket ..
I know in this video ... I should have NEVER hit the sleeve with a hammer .. it seemed to be okay .. What I am wondering .. do the sleeves have rubber O rings/ I put a new head gasket on? Do the sleeve O rings have anyting to do with coolant/water? https://youtu.be/raf0Z6DzAXU Above is a video of the block .. or perhaps the head is warped thanks Gary |
DougS
Posted: 24 May 2017 at 4:09am |
Or a sleeve seal is leaking.
Dick L
Joined: 12 Sep 2009 Location: Edon Ohio Points: 5093 |
Posted: 24 May 2017 at 6:33am |
Once an old sleeve moves the bottom O rings will leak. You can hope with all your heart and they will still leak. I do not know how long it takes however they get hard and will not expand to reseal once the seal is broken after a time. Hitting with a hammer is a no,no but I doubt it caused any damage. The damage causing your leak happened when the sleeve moved.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8758 |
Posted: 24 May 2017 at 8:07am |
put washer on bolt and clamp liners before turning engine
Butch(OH)
Posted: 24 May 2017 at 8:15am |
So many guess about these leaks and there is no reason for it. Remove the valve cover and oil pan and look for the leak and then fix it.
Dick L
Posted: 24 May 2017 at 8:26am |
Watch his video Butch! That kinda takes the guesses out. I don't remember for sure if the core plug leaks were covered on his earlier posts when he had the head removed but I think it was. |
Fred in Pa
Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Posted: 24 May 2017 at 9:37am |
it seemed to be okay is guess work
nonetheless ,still dead. If all else fails ,Read all that is PRINTED. |
Hubert (Ga)engine7
Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6554 |
Posted: 24 May 2017 at 10:06am |
After hitting a sleeve a leaking o ring would likely be the culprit. And it ain't going to fix itself. Listen to Dick L, Fred and Butch;
Dick L
Posted: 24 May 2017 at 11:28am |
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Posted: 24 May 2017 at 4:43pm |
I cringed when I saw that sleeve come popping up.
That hammer is a NO-NO...........you're lucky you didn't split it. Take a look at Dick's head, with NEW freeze plugs......probably will solve your problem. |
gdtractor
Posted: 24 May 2017 at 11:22pm |
THX MUCH !!!!Gary
gdtractor
Posted: 24 May 2017 at 11:23pm |
THX MUCH >> I APPRECIATE IT!!!
gdtractor
Posted: 24 May 2017 at 11:26pm |
THX DICK !!!!
