allis 7060 problem
AC 426 power View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Topic: allis 7060 problem
    Posted: 16 May 2012 at 7:36pm
Its been idling up on its own i was pulling a 1411 new holland diskbine and when the pto was ingaged it seemed like it had no throttle response and would sorta pop and crack i was running in 5 powershift and slow range it has always done fine before. When pto is disengaged it runs better but still feels like its lacking something. Any thoughts?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2012 at 9:53pm
Gov. linkage hanging up in pump-metering valve may need cleaned.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2012 at 9:58pm
Yeah im hoping its just in the pump i also forgot to mention the fuel consumption has also increased by a pretty good margin
Edited by AC 426 power - 16 May 2012 at 10:01pm
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 11:43am
check boost pressure in intake manifold. It could have had a plug fall out, or blow the manifold gasket. Is it smoking heavy black but no power?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 11:50am
Yes it is
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 12:00pm
also, check to make sure turbo is spinning, and not siezed up. A boost gage will tell a lot.
Jim in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim in MO Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 5:35pm
check the fuel filter had one , two year ago lose power it was filter. Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 10:49pm
Thanks for all the help the problem was the primar pump was bad and was sucking air
