Allis 7045 injector pump question |
strollinnolan ![]() Bronze Level ![]() Joined: 27 Nov 2011 Location: Minnesota Points: 5 |
![]() ![]() ![]() ![]() ![]() Posted: 30 Nov 2011 at 5:02pm |
I am wondering if it is possible to turn down the injector pump. 145 hp is way more than I need for running a 4' round baler. The other reason would be fuel savings??? If I am not mistaken the 8030 has the same motor at 130 HP. I am looking more at 120 HP but came across a nice 7045.
TramwayGuy ![]() Orange Level Access ![]() Joined: 19 Jan 2010 Location: Northern NY Points: 11748 |
It is absolutely possible. But a diesel only uses as much fuel as it takes to make the power output. So if you don't use 145 HP, you won't use 145HP worth of fuel.
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5096 |
yes as stated above, if you only demand 120 out of it, that's all it will deliver. there is a torque screw on the pump which does provide an external adjustment, you can turn it in a 1/2 turn at a time. If you dyno it, that will make it easier to set it at a certain point. No matter what you do, a 426 powered tractor will almost always use more fuel than a 301 turbo tractor like a 7000, 7010, 7020.
Orange Blood ![]() Orange Level ![]() ![]() Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
If that 7045 is nice, and isn't all that expensive, you will kick yourself if you don't buy it. :-)
Edited by Orange Blood - 30 Nov 2011 at 6:49pm |
Still in use:
