Allis 190
MilesM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MilesM Quote  Post ReplyReply Direct Link To This Post Topic: Allis 190
    Posted: 10 May 2012 at 5:38pm
Okay we have an allis 190 6 cyl gas now we have replaced the following plugs,wires,cap,rotor,points ,voltage reg,resister and fuel pump problem is now the choke needs to stay out in order to run now I could be missing something but im leaning towards a carberator issue does anyone feel im looking in the wrong place or am I on the right track on this  thanks for feedback
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2012 at 7:33pm
Start with the gas tank and sediment bowl and follow it down to the drain in the carb bowl making sure you have a good flow of fuel all the way. Also check around the manifold for leaks by spraying a combustible fluid ... WD40 works or carb cleaner... all around the gasket area of the manifold and around the throttle bushing. If the engine rpm picks up at any time you have found a leak that needs fixed first before doing anything else.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2012 at 7:34pm
If all of those things check out OK, then start looking at the carb.
2wise4agm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2wise4agm Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2012 at 6:21am
Main jet is plugged in the carb. Pulling out the choke is making it run off the other jet.
stray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2012 at 6:42am
No, the fuel jet is restricted and by pulling out the choke you reduce the amount of air entering the intake and making the fuel air mixture right to run, but you will find that it don't have the power it should have.
1969 190XT series 3
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2wise4agm Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2012 at 8:57am
Sorry, I was thinking of a little different style of carb. Guess I should have said - Try cleaning the main jet.
