Add Remotes to D17IV
Greg_WJP_(WI) View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg_WJP_(WI) Quote  Post ReplyReply Direct Link To This Post Topic: Add Remotes to D17IV
    Posted: 25 Mar 2012 at 11:44pm
I want to add a second set of remotes to my D17IV.  Is it something easy to do?  The first set is routed up to the front for the loader.
Thanks,
Greg
MACK View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 6:26am
Go to salvage yard and buy the parts. Not a big job.  MACK
Gatz in NE View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 6:34am
Adding a valve requires longer threaded rods that hold the stack together.
IIRC, the valve adds 1 1/2".  Best to get them from a 2-valve stack setup (Redi-Rod or All-Thread is not a good choice for this)
And, there's a VERY small spring that goes between the valve bodies.
It pushes on a small poppet check valve.
Dave in il View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 9:02pm
I added a set to mine many years ago when I put the 500 loader on it. Everyhing was still available from Duetz Allis  (I said it was awhile ago) and it was pretty straight forward. It helped having a parts manual.
AGCO My Allis Gleaner Company
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg_WJP_(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 9:22pm
Thanks for the help, everyone.
Greg
