Ac spring tooth or coil tine harrow |
Page 12> |
im4racin
Joined: 12 Jun 2017 Location: Garrison ND Points: 1084 |
Topic: Ac spring tooth or coil tine harrowPosted: 20 May 2023 at 9:44pm |
Anyone have one and where did you find teeth for it? Mine has a couple wraps of wire around the bar then extends down to the ground. How long were the teeth when new? Mine is well worn and want to do some work on it.
Edited by im4racin - 20 May 2023 at 9:54pm |
Dave (NE)
Joined: 12 Sep 2009 Location: Eagle Nebraska Points: 2157 |
Posted: 21 May 2023 at 8:07am |
I have this spring tooth that is mounted on an Allis snap coupler tool bar. Asking $100 for it. Located outside Eagle Nebraska. PM or call Dave cell 402-540-5987 with questions. Was used with a WD for garden plots. Also have some extra teeth I would sell separately. Dave
Do not argue with an idiot. He will drag you down to his level and beat you with experience. Mark Twain.
im4racin
Posted: 21 May 2023 at 10:05am |
Thats entirely different than what i have. I think mine was made by kovar mfg in Minnesota
Dave (NE)
Posted: 21 May 2023 at 11:15am |
Yeah, this is a farmer put together one. Don't know the make of the spring tooth section, but the tool bar came from an Allis cultivator. It was the rear mount section of a front mount cultivator.
guru4hire
Posted: 01 Jun 2025 at 6:31pm |
I have a factory made complete 7 spring tine harrow with guide feet. Seems to be a very rare item. I can provide pics as examples for making parts. Is attached to AC B110 1968 model.
Mikez
Posted: 02 Jun 2025 at 8:34am |
Welcome to te forum. From what you’re describing, you have a garden tractor cultivator. The ones above are on farm tractor.
Are you trying to sell yours.
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4792 |
Posted: 02 Jun 2025 at 12:00pm |
Late to the party again, just like I was making my cultivator and harrow work better. Mine is a early Glencoe, so trash clearance is not great. The trash would flow thru cultivator only to plug the harrow. Harrow teeth are about 12 inches. Mine was warn to 6 to 8 inches when I bought it. So put new teeth on without much help. The secret turned out to be taking the push down springs off the harrow. There is enough weight to make the harrow a good job. But having more up and down movement trash flows thru much better.
ac160
Posted: 02 Jun 2025 at 3:13pm |
Is this the kind of harrow you are talking about?
im4racin
Posted: 02 Jun 2025 at 6:11pm |
No. That’s a cultivator. I have a spring tooth harrow. Look up kover harrow. That will get you close but this I’d way older
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5192 |
Posted: 02 Jun 2025 at 6:40pm |
Why don't you show us a picture of what you are needing parts for? What AC160 posted a picture of IS A SPRING TOOTH HARROW. whatever you have, you may call it whatever you like, but to get the correct parts it help to use the correct name given by the manufacturer. |
plummerscarin
Posted: 02 Jun 2025 at 7:50pm |
AC160,
What brand and model is that? I have one similar set up for 3pt |
guru4hire
Posted: 02 Jun 2025 at 8:15pm |
im4racin
Posted: 02 Jun 2025 at 9:40pm |
If it wasn’t so difficult to post pictures I would. Apparently I have odd ac equipment.
Kenny L.
Posted: 03 Jun 2025 at 4:05am |
Edited by Kenny L. - 03 Jun 2025 at 4:05am |
Kenny L.
Posted: 03 Jun 2025 at 4:07am |
Look like what I posted, they're not for sell.
Edited by Kenny L. - 03 Jun 2025 at 6:53pm |
im4racin
Posted: 03 Jun 2025 at 6:25am |
I'm over this. Go back to the original post and ask yourself how would that even sound like what I'm looking for
Hubert (Ga)engine7
Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6548 |
Posted: 03 Jun 2025 at 7:01am |
Kenny, I have one that uses the feet like you pictured, think it was called a coil shank plow or cultivator. It has front and rear coils mounted on a pin hitch tool bar used on an early model WD. That thing will pull every rock to the top of the ground. Dad bought it in 1948 along with the WD. Never have seen another one like it but Graham-Holme (I think that was the name) made a pull behind version.
ac160
Posted: 03 Jun 2025 at 7:16am |
Kenny, those shovels were also on solid shank cultivators as well.
Edited by ac160 - 03 Jun 2025 at 7:19am |
ac160
Posted: 03 Jun 2025 at 7:17am |
It's an Allis Chalmers snap coupler spring tooth harrow. It's 12ft wide. I have another one as well that's been cut down to 10ft and in a lot worse shape. I can get more pictures of it if you would like some. As a side note the two I have were used in the Missouri River bottom ground pulled behind D17s. The prior owner said it would work the 17 and needed a good bit of weight up front.
Kenny L.
Posted: 03 Jun 2025 at 6:54pm |
im4racin
Posted: 03 Jun 2025 at 10:03pm |
https://www.amazon.com/Chalmers-DRAWBARS-Harrows-Operators-TPL-540/dp/B01C0ZZEJY
That is what I have
Edited by im4racin - 03 Jun 2025 at 10:05pm |
truckerfarmer
Joined: 26 Jan 2013 Location: Watertown, SD Points: 3292 |
Posted: 03 Jun 2025 at 10:21pm |
Prairie Bearing in Canada (prariebearingshop.com) carries tines for Kovar. They have a pdf that shows the dimensions of the different tines. Might help you cross reference to something that will fit. Otherwise Kovar has a website where you can contact them.
'53 WD, '53 WD45, WD snap coupler field cultivator, #53 plow,'53 HD5B dozer Duct tape.... Can't fix stupidity. But will muffle the sound of it! |
im4racin
Posted: 03 Jun 2025 at 10:36pm |
The kovar in Florida isn't the same company even tho they seem to sell similar stuff.
Prairie has good information and will have to investigate. Hershel has 2 listed but limited info. Waiting on engr prints from them Edited by im4racin - 03 Jun 2025 at 10:37pm |
Kenny L.
Posted: 03 Jun 2025 at 11:23pm |
im4racin, are the tines like a railroad spike? I've a Allis harrow that has a evener with 4 section that the tines look like railroad spike but there is no wheels out front. I've not seen one like the one you post a link for, that pretty neat looking. Edited by Kenny L. - 03 Jun 2025 at 11:28pm |
truckerfarmer
Posted: 04 Jun 2025 at 6:11am |
What he is looking for look like rake teeth.
truckerfarmer
Posted: 08 Jun 2025 at 11:00pm |
Any luck finding something that will work?
im4racin
Posted: 09 Jun 2025 at 12:47pm |
Not yet but have found out that Hershel only has one listed that is close but they have a min order of 100. Not buying 100 to find out they are wrong. Back40.ca thinks they can get something. Need to get them dimensions of an original for the next step. Have contacted prairie bearing yet. They are next
Mikez
Posted: 09 Jun 2025 at 9:19pm |
I sent you an email with picture of a tine. Did you receive it
Kenny L.
Posted: 09 Jun 2025 at 9:33pm |
Are these what goes on yours
im4racin
Posted: 09 Jun 2025 at 9:43pm |
Mike…sent you a text
Kenny…that is very close. I don’t have #17 skid but the tine looks right! Thanks for the numbers!
Page 12> |
