AC C inner bearing seal
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Topic: AC C inner bearing seal
    Posted: 14 Apr 2015 at 6:27pm
Question about installing new front inner hub seals on the C.  They appear to just slide on, but they are so tight on hub (the felt side) that it's rotating around the axle (the seal that is).  Should this be tack-welded on to prevent it from spinning?  Or am I missing something here?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2015 at 8:14pm
If it's the OEM type felt seal, it should be soaked in oil, before installing...
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2015 at 9:03pm
Soak it in oil and put aviation gasket cement on before putting the seal on the axle. Also make sure the seal lip on the inside of the hub is clean smooth and greased. Are you sure you have the correct hubs. Wagon hubs look the same but have the seal driven into the hub and the seal rotates against the spindle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2015 at 6:45pm
Got the correct seals.  Same as came off.  I'll do the soak and see how it works.
