AC B Governor
Joose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joose Quote  Post ReplyReply Direct Link To This Post Topic: AC B Governor
    Posted: 01 Dec 2011 at 5:02am
I recently picked up a distributor to replace my magneto on my 1949 Allis Chalmers B tractor. Is there a difference in the governor between the one for the magneto and the one for the distributor? Is there anything else that I should be aware of when switching from the magneto to the distributor?
ACJohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACJohn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2011 at 6:41am
You will have a lot of trouble hand cranking the tractor.  The beauty of a (HOT!) mag is the impulse retards the timing slightly and then trips making crank starting easy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joose Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2011 at 7:32am
I will eventually be mounting a hydraulic pump off the front of the engine to run live hydraulics for a front end loader that plan on adding. So hand cranking will be not be an option.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2011 at 12:52pm
So does the distributor have the spark retarded to TDC. They both have a mechanical advance of 30 degrees for this tractor.
SteveC(NS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2011 at 2:27pm
Joose, I have done just that here's proof. If you have any questions feel free to ask.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joose Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2011 at 4:04pm
Steve, that looks like a real nice set up that you have there. I would like to know how you connected the pump to the front of the engine. I haven't quite figured that part out yet. Did you use a rag joint? I already have the loader and the hydraulic switches. I just have to do some minor fabricating in order to get them to bolt up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2011 at 6:16pm
Joose, I used a lovejoy coupling. I don't know what a rag joint is. I machined the crank pulley to accept a coupling for a 3/4" shaft. The pump mount incorporates a larger tube in which the lovejoy resides.
If you're interested in specifics and pics PM me and we won't have to bother the rest of the world with our blather.
I have a "next generation" improvement that involves machining the crank pulley to become part of the Lovejoy coupling like this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2011 at 3:35pm
Joose, didn't get a pm from you so I decided to post a shot of the pump mount.
the large black pipe is sort of an extension of the pump mount ( the alu. plate mounted to the rad. mount) the lovejoy coupling is inside the short section of black pipe because there's not enough room in the rad. mount.
1953CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953CA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2011 at 4:17pm
Joose;
  I've done the same thing to my 1948 B, mag to distributor swap, I swapped out the complete govenor, weights, gear, and distributor...Biggest thing is the nipple on top of the govenor needs to accept 2 oil lines, one from the head to the govenor, and then the other to the distributor housing.
Andrew
1945 AllisCletrac / 1948 "B" / 1953 "CA" / 1955 "WD-45" / 1963 "D-15 Series II"
"No Air Support without Ground Support"
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953CA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2011 at 4:19pm
