AC 1300 field cultivator
IHCfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IHCfarmer Quote  Post ReplyReply Direct Link To This Post Topic: AC 1300 field cultivator
    Posted: 02 May 2018 at 7:17pm
Are there any setup Instructions for my new to me 1300 Field cultivator?
It looks like the hitch is Adjustable and seems a little bit too high the front teeth are not digging in! Thanks
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2018 at 7:29pm
Depending on how high your tractor's drawbar sets, you will want to adjust the 1300's hitch so that it digs level - front to back.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IHCfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2018 at 7:53pm
Another couple Questions where can you get the shanks for it? And can you put IH earth metal sweeps on it? Earth metal last longer then anything else you can get! Thanks
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2018 at 9:00pm
The AC field cultivator sweeps are a angle than most. If not right they will not go into the ground very well
Post Options Post Options   Thanks (0) Thanks(0)   Quote IHCfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 3:03pm
Anyone have a operators manual for a 1300
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 10:23pm
Sweeps are a row crop sweep so they are 54 degree not 47 like most so case ih earth metal sweeps will probably not work.
ryan
ezlle71 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ezlle71 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2018 at 11:55am
We have two 1300 field cultivators, one to run, one for parts. My dad has called them a certified dump rake for years lol. They do a great job but will pickup every piece of trash and string and everything else in the field. And yes they are a different angle sweep than most. We have pretty much retired ours since getting a Krause field cultivator.
190XT, 185, D15 SII, 7040 is living again, 7010 retired for parts.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2018 at 8:11am
Allis uses a 54˚ shovel which I couldn't find any in a 4 inch so I got 47˚ shovels and put two or three washers between the shovel and shank at the bottom bolt. Cheap crappy Chinese washers from Fleet Farm take three compared to two washers from the local CaseIH dealer.
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2018 at 8:13am
Old design meant for full tillage. 1400 series are much better.
Wink
I am a Russian Bot
This page was generated in 0.033 seconds.
