8070 lights
leoversteeg11 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote leoversteeg11 Quote  Post ReplyReply Direct Link To This Post Topic: 8070 lights
    Posted: 11 May 2017 at 2:06pm
I don't have a wiring diagram handy. Every light and flashing light is working except for all four flood lights on the back. Where should I be looking for the problem. Lights are not burned out and the connector plugs aren't dirty or rusty. Thanks
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 6:14pm
Check main harness connector in front of cab, you will have to remove the heat shield to get to it.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 9:32pm
could be in the switch... there's an updated switch from agco.....specially if ya have problems with the flashers/turn signals
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 11:18pm
could they have added an extra switch for them?
This page was generated in 0.041 seconds.
