6080 AC no throttle response
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: 6080 AC no throttle response
    Posted: 22 May 2012 at 6:13pm
My 6080,s actin up a little , you push the throttle handle up to open her up and nothing , you pull it down and push it up again and it works perfect ; what the h--- is going on ??
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2012 at 9:00pm
sticking metering valve. Probably time for pump freshening.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2012 at 9:15pm
Is the linkage loose on back side of pump?   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 3:40am
Yes its all loose
ky wonder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ky wonder Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 5:13am
unhook the linkage at the pump and see if it does the same thing by hand
before you go to tearing off the pump
sounds like it could be a loose andslipping cable to me
i like old tractors of all colors
