$5 diesel fuel usage |
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3815 |
Topic: $5 diesel fuel usagePosted: 18 Apr 2026 at 7:39am |
Farmers running 500hp 4wds doing spring tillage are probably burning 20 gallon/hr @$5/gal ~ $100/hr per that one tractor? So during long hour spring days (16-18hr+) that could become $1600-1800 / day fuel cost per that one tractor?
If that 4wd is pulling a 50’ FC @ 7mph, in theory without headland turn time factored, that becomes 42.4 acres / hr per $100 of fuel. Or, $2.36/acre fuel usage. If in reality, 10% of travel was utilized for turning, then fuel usage is probably closer to $2.62/acre? That’s factoring a square 40 acre field ( 1300’, minus 50’ headlands(1200’ passes?) considering a constant soil pull load on FC, which is probably seldom the case? Same could be applied to semi tractor trailer rigs moving goods up & down our roadways. Most 80k loaded semis could be averaging 5-6 mpg (11-13 gal/hr x $5/g ~ $55-65/hr) ?? Some lighter freight semis may average a little higher 7-9mpg (7-9gal/hr x $5/gal ~ $35-45/hr) ?? |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 36773 |
Posted: 18 Apr 2026 at 8:32am |
Is starting to turn lower. At least here, avg is around $4-$4.40 and coming down a little at a time. HOWEVER, as many I speak to here note, when already cutting close as to break even of Corn or Beans or Wheat, a few are not bothering to plant. NOT taking loans to buy materials or get on lists for Fertilizers or Seed.
plummerscarin
Posted: 18 Apr 2026 at 7:43pm |
Well, that's if you're buying road deisel from the pump. Which BTW was $4.96 at one station today. Though others were still $5.19. Certainly, many are buying ag fuel which doesn't have all the road use taxes added? As an example, I paid $3.69 for ag fuel but that was before Iran got bombed. Pump price was more than that at the time
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12524 |
Posted: 18 Apr 2026 at 8:22pm |
Fuel per acre is peanuts compared to fertilizer per acre, which is NOT going down.
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8605 |
Posted: 23 Apr 2026 at 6:51am |
The gallons per acre, for the most part doesn’t change a whole lot per the job being done. The big variable is acres per hour, this is achieved greatly by the size and configuration of equipment being used.
