230 / 262 Engines
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Topic: 230 / 262 Engines
    Posted: 04 May 2010 at 8:30am
 Could anyone clue me in as to external differences between these engines? How to tell one from the other?  Thanks ,Gary    I should clarify , I am refering to gas, not diesel.
Edited by Gary in da UP - 04 May 2010 at 8:51am
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2010 at 8:48am
I think the 230 has two oil filters
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2010 at 3:32pm
Gary.
  The 230 engine has the waterpump mounted to the head. The 262 waterpump is on the front of the block.
Richard
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2010 at 3:38pm
I think Tom MN might know for sure, but it seems like he had all of the various versions of the 230 posted with his WD45D rehab. If I remember correctly, the Buda engines in a Cockshutt only had 1 filter, amongst other little differences.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2010 at 3:42pm
 Thanks, fellas.
Sam T-Ga View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam T-Ga Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2010 at 4:58pm
early 262 had water pump mounted to head also. 230 have 2 oil filters with seperate bases like 226. earily 262 had 1 oil filter in a can, later was a spin on, only difference was the base. 262 has 2 mounting blocks about 2" sq and stick from block about 1 1/2" from block on left side, on diesel the fuel filters are mounted there. I had to grind off front one on my 262 block to get WD45D pump to mount.  Same blocks and cranks were used for gas or diesel. Sam T-Ga.
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2010 at 6:59pm
Most if not all 230s have grooves in sleeve od  for orings and 262  had tapered  skirts on the od of the sleeves for their orings. We used to make them at Sealed Power in Rochester In.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2010 at 7:15pm
The 230 gas engine in my old "A" combine has one oil filter on it and the water pump is mounted on the head. I thought Gary was asking about a gas engine. Well that's what I get for thinking. LOL
Don
