2000 Series Plow Bottoms |
JimWenigOH
Topic: 2000 Series Plow BottomsPosted: 27 Mar 2026 at 8:51pm |
The Parts Catalogs for these plows do not list any of the various styles of bottoms used. Where or what catalog would show the parts for the different bottoms and coulters? Also is there a description somewhere listing the benefits/purposes of the different bottoms and accessories on the 2000 Series plows? The Operators Manuals don't contain this information either.
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 730 |
Posted: 27 Mar 2026 at 8:58pm |
I had a 2000 5 bottom and have a 3000 now. They both had 387 bottoms. Thats the only reference i have
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5284 |
Posted: 28 Mar 2026 at 6:42am |
The bottoms coulters and jointer are in a separate parts catalog all to themselves. I suppose there is some sales literature that describes the differences and benefits of the different bottoms, however I've never seen anything from Allis Chalmers doing so. I have seen this published from other manufactures.
Any Allis Chalmers bottom will bolt to any Allis Chalmers plow.
Mikez
Posted: 28 Mar 2026 at 7:18am |
The parts book that I have for the 2000 plow has the different bottoms and coulters in it. As well as the agco on line parts book. The 387 is the only bottom I know of that parts are still available.
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3675 |
Posted: 28 Mar 2026 at 12:50pm |
The short wing 386 and 387 used the same 4 bolt point - the 392 394 used a 5 bolt share You could get 14 16 or 18" points in different configurations. I remember Bullet points, Deep Suck points , hard surfaced etc... Herschel shows the 4 bolt in 16" and 18" the 16" can be used on a 14" plow.
Edited by tbran - 28 Mar 2026 at 12:59pm |
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3672 |
Posted: 28 Mar 2026 at 9:45pm |
I have 2 different AC 2000 plow brochures. Here is what they read about their moldboards. In general, all offered 3 bottom reset choices~ Automatic (hydraulic accumulator), spring trip, or shear bolt. Could be ordered as 3-8 bottom configurations.
AC Plow sales brochure AED-297/7301 (Ag Equip Div. 297, 1973, January. It says the AC Monoframe 2000 could have choice of 3 moldboards; 387 “”general purpose moldboard. Has exceptional covering & soil fracturing ability.. is suited to most areas. It’s hefty frog extends well down on the plow share for extra protection against stones.” 386 “short moldboard. Has same rugged construction as the 387, but the moldboard is shorter & has more curvature for increased scouring ability. It also works well in extremely sandy soils. 390 “high speed moldboard. Has a 37deg angle of approach to the soil and is recommended for fast deep plowing. They could be ordered as a 16” or 18” cuts. All had vertical clearance of 28.5”. AC Plow sales brochure AED 405/7605-R (1976 May). It says the AC 2000 series Monoframe could have choice of 4 moldboards; 386 “has a 45deg blade for good soil fracture & a short moldboard for improved scouring ability. It also works well in Sandy soils.” 387 “has a 45deg blade for good soil fracture & a full moldboard for improved trash covering ability.” 392 “has a full moldboard for high speeds and light drafts and a 35deg blade for high speeds and light draft.” 394 “slat bottom is designed for soils where difficult scouring problems exist. By reducing the soil contact area, the draft load & the scouring characteristics are improved.” Could be ordered with either 16” or 18” cuts & all had a vertical clearance of 32”. Edited by AC7060IL - 28 Mar 2026 at 9:59pm |
AC7060IL
Posted: 28 Mar 2026 at 10:23pm |
For the AC 2000 Monoframe plows, their model configurations were 7, as follows;
Model 2363 which breaks out as follows; 2(2000), 3 (3 bottom base), 6 (16” cut), 3 (3pt hitch, category 2 or 3 in furrow). Model 2383 ~ same except 8 (18” cut). Both 2363 & 2383 could “add a bottom (4 bottoms). Same break outs apply to following models; Model 2463, 4 base to 5 add-on. Model 2483, 4 base to 5 add-on. Model 2563, 5 base to 6 add-on. Model 2663, 6 base to 7 or 8 add-on(s). Model 2683, 6 base to 7 add-on. The above Model configurations were used for both the 1973 28.5” clearance plows & 1976 32” clearance plows. Edited by AC7060IL - 28 Mar 2026 at 10:31pm |
Buddy2366
Posted: 28 Mar 2026 at 10:47pm |
I have a 2000 Monoframe 2483, rubber cushion coulters, that I think has 28.5" of clearance, so I take it is a 1973 version. It has no serial tag anywhere I can find, so I had no idea when it was made. Im assuming it has 387 bottoms, but cant locate any parts #s. I bought a parts plow that is a 2000 2563, and the moldboards are defiantly different. They look longer and a bit narrower. Havent had time to remove them to compare. Were all these plows painted Persian#2? I probably just screwed up by painting mine Corporate Orange! Looks good if I do say so myself.
Edited by Buddy2366 - 28 Mar 2026 at 10:52pm |
AC7060IL
Posted: 28 Mar 2026 at 11:54pm |
I found a 3rd AC 2000 Monoframe Plow sales brochure in my collection. FE 665 printed in U.S.A. / 6807, 1968, July. In general, they too offer 3 choices of bottom reset ~ Automatic (hydraulic accumulator), spring trip, & shear bolt. All are 28.5” vertical clearance. Only 16” cuts were offered & 2 Models, each with an add-on bottom option.
2563, 5 base, 6 add-on. 2463, 4 base, 5 add-on. For moldboard options, It reads as follows; 387 “is a scouring bottom with a 45deg approach to soil. Exceptional covering and pulverizing.” Other choices; 371 “for black waxy soils.” 372 “with medium curvature.” 373 “for sod.” 374 “slat bottom where scouring is a problem.” 375 “with steep moldboard.” 376 “with high lift. Shin and adjustable trash coverers.” |
AC7060IL
Posted: 29 Mar 2026 at 1:03am |
Digging a little deeper about AC plow moldboards, and going back into the 1960s prior to the 2000 Monoframe plows, I have 3 more AC plow brochures as follows;
60,70,&80 series plows TL 2686-632, 1963, February. It list the following bottoms noted as the “370 series moldboards.” 371 “this bottom is designed for plowing black, waxy and tight soils or hard scouring conditions. No 371 has the least curvature of the 370 series moldboards.” 372 “A general purpose bottom for versatile work and a wide variety of soils. Medium curvature. 373 “For sod or stubble plowing, championship style furrows, where complete turning of the furrow slice is desired. A full curvature moldboard. 374 “ Where scouring is a real problem, this slat bottom is a natural! Does a good plowing job in any soil. Right hand & left hand bottoms available. 375 “A steep moldboard with increased cutting angle for plowing hard-to-scour soils where a solid moldboard is favored. Good trash covering ability. A very popular general purpose bottom. Right hand bottom only. 376 “This high lift moldboard lets you put a plow down deep for turning up soil that has never seen daylight. Same curvature as no .372.” AC 9000 series FE 170A / 659, 1965 September. It offers the same 6 “370 series” bottoms. AC Moldboard Plows FE-428 printed in U.S.A. / 6704, 1967 April. It includes the following models; 9000 series semi mounted & pull type, 60,70,&80 series plows. Perhaps it debuted the 387 bottom? It says the following about it; “is a high scouring bottom with a 45deg approach to the soil…. Has exceptional covering and pulverizing ability. It’s hefty frog, 5/16” moldboard and heavy-duty share will stand up in rocks, and its tapered bolt heads will stay in place when replacement time comes.” Optional bottoms include the 6 from the “370 series.” Edited by AC7060IL - 29 Mar 2026 at 6:25am |
AMDG
Posted: 29 Mar 2026 at 6:02am |
I have the same plow with rubber cushioned coulters. I am missing a coulter along with the arm the coulter connects to. Are there any used part sources available for these? Thanks
Ad Majorem Dei Gloriam
AMDG
Posted: 29 Mar 2026 at 6:04am |
I have the plow with rubber cushioned coulters. I am missing a coulter along with the arm the coulter connects to. Are there any used part sources available for these? Thanks
Mikez
Thanks(1)
Posted: 29 Mar 2026 at 6:38am |
Amdg theres two different versions of rubber spring coulters. Look in parts book and let us know which you need
AC7060IL
Posted: 29 Mar 2026 at 6:47am |
Your 16” cut parts plow 2563 if 28.5” clearance could be either a 1968 or 1973 ?? But if it’s 32” clearance then 1976. |
tbran
Posted: 29 Mar 2026 at 8:55am |
The AC NO-Til coulter use the same spring - still available last I checked but pricey.
8070nc
Posted: 29 Mar 2026 at 10:38am |
I have 7 bottom 3000 plow that came with rubber spring coulters. Every one fell off. I got one from agco. He said it was the only ine he could find. It fell off too. Id like to put it back like it came but i have no idea where to get those rubber springs. Id entertain any suggestions
1984 80780
Buddy2366
Posted: 29 Mar 2026 at 12:59pm |
So did the rubber cushion coulters come out when the 32" 1976 version was introduced? Or were they available before that?
JimWenigOH
Posted: 29 Mar 2026 at 2:13pm |
Hey Mike, what is the Form # of your Parts Catalog and year? Mine is 9001325 dated April/70, and covers 2000 & 3000 Series.
JimWenigOH
Posted: 29 Mar 2026 at 2:22pm |
I have a couple extra, near Kenton, OH. How long the "glue" would last under use, is anyone's guess. I'm sure there are companies that bond rubber to steel, one would just need to do some research.
JimWenigOH
Posted: 29 Mar 2026 at 2:26pm |
Thanks for the trove of information, I believe that covers all my questions and more!
JimWenigOH
Posted: 10 Apr 2026 at 5:38pm |
Mikez gave me the information on his Parts Catalog that has the "latest" parts listings. It is Form 79005147, dated JULY 1977 and is still available from AGCO, $18.45, with 75 numbered pages. Just received mine today. Thanks for the information Mike!
Mikez
Posted: 4 hours 15 minutes ago at 9:59pm |
You’re welcome Jim. Reasonable price for parts book
