1954 G dies
cabinfourus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cabinfourus Quote  Post ReplyReply Direct Link To This Post Topic: 1954 G dies
    Posted: 04 Mar 2026 at 11:46am
Hey guys,
I am working on a 1954 Allis Chalmers G garden tractor for a friend. I have been working on this thing for a few months now, and I am starting to lose hope.
My problem: At the first start of the day, the tractor will run fine for 3-4 minutes. Once it warms up a bit, it dies. It acts like it is running out of gas. It will restart and run for a few seconds but die once again. When it starts to die, it makes a weird metal scraping noise from the crankcase (I think).
Things I have replaced: points, condenser, fuel tank, fuel lines, fuel sediment bowl, wiring harness, main on/off switch, and the carburetor.
Things I have tried: rebuilt the old carburetor, reset the timing, and used new fuel without the 10% ethanol.
The timing on this little engine is a bit confusing. Some say the number one cylinder is close to the radiator; others say it is close to the timing gears/crank pulley. It ran fine when I used the cylinder closest to the radiator for number one, but I am truly not sure which end number one is located. Is the number one cylinder located on the end with the fan belt or nearest the tractor seat?
Thanks for ANY and all help.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2026 at 6:49pm
#1 is to the rear(belt end) timing mark is on the bottom pulley (#1TDC is straight down 6 o’clock)
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote cabinfourus Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2026 at 7:51am
Thank you! I had it wired backwards then. It ran fine but not for long.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2026 at 8:01am
the coil looks new... but if all else fails , try a different coil / condenser... sometimes even NEW have a problem.... when they get HOT, you can get an open circuit..
Edited by steve(ill) - 05 Mar 2026 at 8:02am
Post Options Post Options   Thanks (0) Thanks(0)   Quote cabinfourus Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2026 at 11:21am
I plan to try another condenser and points, but that is the third coil we tried.
I actually rebuilt the distributor a couple of days ago. (bearings, etc.)
This thing has been a nightmare for me.
Edited by cabinfourus - 06 Mar 2026 at 11:23am
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2026 at 3:27pm
Any update?
I see what appears to be new head bolts, but I don't see any notes of what else you may have done so far, so please consider that when reading what follows...
Flatheads have another peculiarity that'll cause this kind of thing...  carbon soot buildup on the valve stems... it cakes up, and as the engine warms, the stems bind in the guides, causing them to not close fast enough, not seal up tight... which causes manifold vacuum to drop, and makes the engine seem like it's running lean, starving for fuel.  Let it sit for a half hour, the stems cool, valves relax to the seats, and it'll start right up.
The giveaway?  When it stalls, turn it over by hand, and listen at the throat of the carb and exhaust.  As you come to TDC on every cylinder, listen for a hiss... that means you've got a valve leaking.  If it doesn't build much compression (or any) while you're hearing that, you've got sticky valve guides.
This isn't a 'difficult' fix, but it takes patience, at least, for the first engine you do.
Shut off fuel, Drain coolant, disconnect fuel and throttle/choke linkages, spray the head/manifold bolts with penetrant.  Take off the upper coolant hose, and... if you're NOT ABSOLUTELY CERTAIN there's no head valve under the thermostat, pull the upper neck and thermostat.
Unbolt the manifolds, swing the exhaust out of the way.
If there's a distributor coming out the top, you'll need to pop the cap off, loosen the retainer, and lift out the distributor... HOPEFULLY enough wire on the ignition that you don't have to disconnect it.
Unbolt the head... pay attention to bolt lengths, if they're not all identical, MARK the sizes for their respective holes, and WRITE IT DOWN!
Put on a mask and goggles, and scrub the cylinder head CLEAN.  Remember- this engine has been around a while, there's probably been some leaded gasoline through it, so the carbon soot you're breathing, will be an excellent way to get a little lead in you, so treat it with caution.  Put a good straightedge on the mating face of the head, see if it's flat and true.  If not, take it to a machine shop and have 'em touch it up.  Put a straightedge on the top of the block, and look for anything serious.  With the head flat, the block can be a little off and still seal up good with a factory copper gasket.
Remove the side covers (valves).
Take a sheet of aluminum foil, and wad up pieces to make plugs for the drain holes in the side covers.  This will keep STUFF from falling into the bottom of the oilpan...
Apply a spring compressor, and remove the valve spring keepers (a magnet and a pair of larger hemostatis is handy for this... if you drop one into the oilpan, you'll be angry that you didn't wad up some aluminum foil...
Now fold a piece of foil and place it as a cover over top of all the tappets... keep 'em crud-free for the next few steps.
Look closely at each keeper and spring.  If you see anything that is unlike the others, act on it accordingly.
Lift out one valve, and remove it's spring.  Place them in order as you do it.
Wire brush the valve stem, neck, and head....  I chuck 'em a cordless drill, and use a motor-mounted wire wheel to clean them up.  Once brushed clean, WRITE the cylinder and position on the head of the valve, then continue to next.
Once all done, place all springs on flat surface, look for oddities.  Short springs need replaced.  If you have a friend with a valve spring tester, have 'em all checked for tension.
Take scrapers, and a Dremel with wire wheel, and scrub the crud out of all the ports.
Use a valve stem 'cleaning reamer' (its a springy blade thing) and some penetrating oil to clean crud from the inside of each valve stem.  Check each guide with it's respective valve... it should fit well, and not be all sloppy, and not bind up.  If you have a bind, run the reamer a little more, testing frequently.  If you have big slop, pulling out a guide, dropping in a new one, and recutting the valve seats is a wise solution.  Seems serious, but it's not.
Get out your lapstick and lapping compound... put a little of the gritty paste on a valve's sealing surface, smack the lapstick to it, and spin it between your hands.  Feel the grit- it'll start out feeling roughish, and after a couple cycles, it'll start to smooth out.  Once it's feeling smooth, pull up the valve, wipe it, and the seat off, and look- you SHOULD see a nice shiny track where the valve polished itself into fitment.  Call it good and move to the next.
Once all done, loosen the tappet adjusters (two small wrenches), then install the valve springs with compressor and retainers.  Retainers won't WANT to just 'stay' where you put them while you fiddle, so put a dab of axle grease on 'em to help 'glue' them in place for the process.
Once all are in, you'll need to get feeler gauges and put a socket wrench on the crank to rotate... reset your valve clearances (should be in the engine's maintenance specs, usually 0.020-0.030" lash or so.  If you don't leave enough lash, the valves won't seat and seal... and when the engine is hot, the stems will expand enough such that the valves won't seat, right?
Don't forget to take out your aluminum foil before closing up the side covers.
IF you're going through this process, another thing that's good to do:
Pull out the head gasket.  If it's copper, it's PROBABLY re-usable, so try not to damage it... examine it closely for signs of leak-throughs.
Pull the block drain plugs, water pump, and any covers open to coolant.  Flush the block, and poke into all the water jackets with rods, brushes, porcupine quills, your wife's knitting needles, house wire, an old pair of crutches, a ski pole, Uncle Leo's fishing pole, chopsticks... whatever you can get.  Flush crud out 'till you can't get any more crud to come out.  Drain the radiator, flush it out... mebbie take it to a radiator shop and have 'em boil and pressure test it.  Consider rebuilding the water pump.  Look at the front crank seal, if it's leaky, pull that front sheave and get a new seal in it.  Sediment accumulates over time in these things, I have no idea why, but I've never found one that'd been closed up for 50yrs and didn't need a rinsing-out... sometimes, I had to chip chunks out... but ALL of them ran much better after I did.
Wire brush all the bolts clean, chase all the threads with a tap to clean them, Put it all back together.  On the head bolts that go through to water, I apply pipe paste sealant, as I've found that it solves LOTS of problems.  Torque the head using proper pattern!
Make sure you've got good seal on the exhaust and intake manifold faces, give the carbeurator a bath in the ultrasonic cleaner... (note that the fuel inlet fitting on many carbs has a little catch-screen IN it, and people don't know about it... so when it gets plugged, she'll starve.
With this freshening, even a worn flathead will wake up considerably.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2026 at 5:37am
We all normally think of the front cylinder being #1. In the G, Allis Chalmers mounted the little Continental engine backward in the tractor.
This engine was used in several different applications. I believe the Cockshutt Pony used the same engine and I have seen industrial air compressors with similar engines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cabinfourus Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 38 minutes ago at 11:39am
I am sorry it has taken so long to get back to this, but I have been very busy with work lately and have not had time to come back to this project. Let me also say, thank you, to everyone who has offered advice. This little tractor is going to be the death of me. The man I am fixing it for is now 88 years old and now has cancer. He loves this little tractor and wants to ride on it one more time before he passes. I just want to help him with this bucket list item and have not been charging him for any parts or repairs. He is a wonderful human being, and I am proud to call him my friend.
The tractor is still not running. Of course it is because I have not worked on it any.
I don't have much experience with flat heads, but I plan to try what you have suggested here. The engine was overhauled by someone else, and after the overhaul, it never would run more than a few minutes before acting as if it were running out of fuel. I can spray carb cleaner into the carburetor when it starts to die, but it will still act as if it is running out of fuel. Also, it has started making a weird scraping noise. It gets louder with higher RPMs and sounds like it is coming from the middle of the block. The scraping noise is new.
Repairs I have made and tried:
1. Replace all spark plugs
2. Replaced all spark plug wires
3. Rebuilt wiring harness
4. Rebuilt and later replaced the carburetor with a new one.
5. Replaced all fuel lines and fuel tank
6. Replaced coil (three times)
7. Replaced points (twice)
8. Replaced condensor (three times)
9. Replaced fuel bowl
10. Ran a compression test (I forget the numbers, but they were within specs)
11. Replaced battery
12. Installed ballast resistor at coil (it was converted from 6V)
13. Rebuilt distributer
14. Replaced rotor button
15. Removed timing cover and checked mechanical timing
16. Set timing according to the service manual
17. Replace ignition switch
After I try what you have suggested, I will get back with you and let you know the results. ****fingers crossed and praying*****Tongue
This page was generated in 0.158 seconds.
