1937 AC WC Compression Normal Reading |
wembry
Joined: 13 Jun 2010 Location: Liberty, Mo. Points: 1 |
Topic: 1937 AC WC Compression Normal ReadingPosted: 13 Jun 2010 at 8:43am |
What is the normal reading?
Thanks in advance,
Wayne Embry
Kraig (WI)
Joined: 19 Sep 2009 Location: Fairchild, WI Points: 163 |
Posted: 13 Jun 2010 at 9:50am |
If it's the same as a WD, it would be about 110 psi. My WD cylinders are all about 100 psi.
Kraig
7010,D17D,WD45,WD,WC,WC,B,
Gleaner K,60,66,72 |
Jacob (WI,ND)
Joined: 11 Sep 2009 Location: Kenmare, ND Points: 1249 |
Posted: 13 Jun 2010 at 11:42am |
According to my WC shop service manual:
(Which you can get here: http://www.3000toys.com/allis/manuals.asp) Gasoline engine - 95 lbs. Low octane fuel engine - 75 lbs. Aluminum Piston 217311 - 104 lbs. The important thing I have heard and read is to have a consistent amount in all 4 cylinders. If one is way different, then you have other issues. Hope this helps, let us know how you make out.
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45 |
