190XT PTO coupling
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: 190XT PTO coupling
    Posted: 07 Feb 2016 at 8:13pm
So I went and removed the PTO housing on the XT and the coupling dropped out because I forgot to engage the PTO lever before taking things apart.  What is the best way to get the coupling seated where it belongs again?  I removed the hydraulic sump, but there is still very little room to get that bugger in its place.
Would it be easier to put it back by going in through the inspection plate on the right side where the power director valve is?
I appreciate any suggestions!
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2016 at 8:39pm
Go through plate on right side. May need another hand to engage lever when you get every thing lined up.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2016 at 8:56pm
Thanks Mack!  Is there any trick to removing the power director lines or working around them?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2016 at 9:16pm
Best to find a good looking blond with a small hand.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2016 at 9:19pm
I am more partial to brunettes myself!  Thanks for the tips!
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2016 at 9:29pm
small hands...make everything look bigger!
