sun star deck question
tractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Topic: sun star deck question
    Posted: 12 Aug 2014 at 10:38pm
any body have experience with blades hitting each other on a sunstar deck ?   how do i fund out how to fix ?
Play on 38 B 49 WF , working on D14, D15 B10, Bee 12 B110. use 185 and 190
Brian S(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian S(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2014 at 6:32am
Not sure what that is but.. sounds like the blades are Too long? or need to be off set?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2014 at 9:18am
Are they a timed blade ? Gearbox type so blades do not rotate freely .
Check spindle location if not to be sure clearance is between blades, also position that blades turn true to spindle with both blades the same height as they turn .
 bad bearings , bent shaft, bent deck, spindle shimmed wrong or loose mounting.
Set up on solid surface and measure blade height as they swing arc, deck height should be slightly lower in front than rear, but same in front and side (90deg from fwd) .
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2014 at 8:11am
it's a shaft drive to the  deck, but the blades are belt driven , arbors seem tight no obvious signs of out of place or bent. i did have a broken blade mounting plate, i bought new and haven't tried it yet, will do today.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2014 at 4:45pm
I haven't had that problem but keeping them tight has become a big problem
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2014 at 9:09pm
grind or cut em off
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2014 at 9:12am
that may be next, but i think something is bent i would like to find what it is. Just don't know where or how to measure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2014 at 8:47pm
my simp dealer in la crosse wi  suggested i may have a bad bearing, take tension off belt and pulleys, and shake blades, if they wiggle  top arbor bearing is bad.  I will try  tomorrow, to pooped to do tonight.
