715 backhoe tranny trouble
Dgrader View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dgrader Quote  Post ReplyReply Direct Link To This Post Topic: 715 backhoe tranny trouble
    Posted: 29 May 2015 at 10:07pm
Our 715 started making a grinding sound in 3rd gear last fall. As we kept using it, it got to where it was doing it in 1st and 2nd also. 4th gear was fine, didn't make any noise at all. Today I decided to take out the tranny and see what was going on. 1st,2nd and 3rd gear were all in good shape but 4th was a mess. The teeth were ground off from the front of the case, leaving about a half inch left back by 3rd gear. I'm thinkin when in the first 3 gears there's enough slop in 4th to make the grinding sound. But in 4th there's enough teeth left to make it run smooth. I hope this makes sense just trying to figure out what's goin on. Any thoughts would be appreciated. Thanks.
Ya cain't fix stupid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2015 at 10:19pm
Sounds like box needs to be gone through and check forks are putting gears in proper position
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dgrader Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2015 at 5:18am
Yeah Coke, I dropped the tranny and found bearings went out on bottom shaft. Found a used tranny and put it in and everythings workin fine. Would you know where to find the parts to rebuild our old one? Torque converter was made by borg warner and I'm assuming tranny was too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2015 at 11:32am
can check if any part numbers might match with truck units used by ford .
might be couple individuals on here that can source parts also either in MI or Canada
also MINNPAR might have lead - bearing should be easy to find .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dgrader Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2015 at 4:20pm
Thanks Coke. I'll check it out. Preciate it.
ivan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ivan Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2015 at 7:42am
we can help 989-379-2721
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2015 at 10:49am
See - Ivan seems to be able to step in on many of these things
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dgrader Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2015 at 5:47pm
Ok ivan. Not sure what we're gonna do yet. If we rebuild we'll give ya a call. Got othet stuff to fix first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dgrader Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2015 at 4:26am
Ivan, you wouldn't have a muffler for the ol girl would ya. It was shot and put a straight pipe on. Gotta quiet it down.
