Wide Front Allis C Wishbone Support Slop |
Post Reply |
Author | |||
C in Concord
Bronze Level Joined: 26 Sep 2019 Location: Concord, WI Points: 109 |
Posted: 16 Jan 2020 at 12:52pm |
Hey All,
I've got an Allis C with a B wishbone wide front and noticed quite a lot of slop (~3/16") where the wishbone support bolts to the bellhousing (aka the rear axle pivot, I think), see image below. Looks like whoever converted it to wide front didn't have the bushing...? I've been unable to find anything that seems right through Steiners, DJ's, eBay, etc. My measurements suggest I could drill out some 3/4" schedule 40 pipe with a 7/8" drill to make one. Thoughts? Any help is appreciated!
Leave things better than you found them.
1941 Model C (restored 2020) |
Sponsored Links | |||
PaulB
Orange Level Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4383 |
That should be a bronze bushing, part #210680. Mike Z had one listed in his NOS parts a few days back.
If you can't make it GO... make it SHINY |
Lon(MN)
Orange Level Joined: 11 Sep 2009 Location: Elk River,MN Points: 1902 |
I go to my shed an pick out a nice torque tube and use that. Sorry that's what happens when you collect and don't toss anything.
CTuckerNWIL
Orange Level Joined: 11 Sep 2009 Location: NW Illinois Points: 22807 |
I would take it apart, measure the bore and the spud, then go to Graingers and find what I needed.
If things aren't round, that would have to be addressed first, in order to find the right size bushing. https://www.grainger.com/category/power-transmission/bearings/sleeve-and-clip-bearings/sleeve-bearings?cm_sp=Product_Details-_-Categories_Based_on_Your_Search-_-IDPPLACAT |
LouSWPA
Orange Level Access Joined: 11 Sep 2009 Location: Clinton, Pa Points: 24018 |
For what is worth, I find McMasterCarr far better than Graingers.
Anyways, I would think you will need to ream/drill the hole out to something near round, then obtain the proper bushing stock to fit the hole, and then drill/ream it out to fit |
I am still confident of this;
C in Concord
I'll know more after this weekend, but the hole is not noticeably obround (yet). Problem is it measures ~1.060" & the bushing has to fit over 7/8" threads. I scoured McMaster-Carr (tend to agree with you Lou), but the closest I could find for less than $80 is 1" OD. That's why I thought the 3/4" sch 40 iron pipe would be better, ~1.05" OD & cheap.
Dusty MI
Orange Level Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5050 |
I found the one on my D-10 was not good, and no way to lube it, so I added a grease zerk.
Dusty
Sugarmaker
Orange Level Joined: 12 Jul 2013 Location: Albion PA Points: 8166 |
C in Concord,
I like your approach to leave it better than you found it! If that bushing from grainger is about right it looks like a inexpensive way to go. Suprized that Mc Master Carr did not have equivalent in size material and price too. They are my go to place for items like that too. We need some additional pictures of your C with the wish bone B axle too! Regards, Chris
Dick L
Orange Level Joined: 12 Sep 2009 Location: Edon Ohio Points: 5082 |
I have never seen one with a bushing. Won't hurt to have one.
You have more wear points than the hole. |
Mikez
Orange Level Access Joined: 16 Jan 2013 Location: Usa Points: 8089 |
The part number Paul said to use that I have is steal
It's about 1-1/16 long X 1-1/32 or 1-1/16 OD X 29/32 ID Edited by Mikez - 17 Jan 2020 at 8:39pm |
Mikez
Hey guys is there a bushing or anything in the front pivot. Could you check your parts book for me.
Thanks |
C in Concord
A little house keeping...
In looking at the Agco parts site, they claim B43220 & up had the bushing (15 in the image below; part# 210680). If I'm reading it right... That would mean it occurred during 1940 production, which aligns with my situation.
I ended making one out of 3/4" black iron pipe. After spending some quality time with my bench grinder, I got the OD to fit. Size ended up close to Mike's #'s, 1"L x 1-1/32"OD x 7/8" ID. Should work while I wait for the real one from Mike.
I sent you a PM to this effect also, but there is no bushing in the front pivot (per the Agco parts site again). Thank you for asking though! Hopefully you can find the pivot bolt (18) and collar (22)... I think that covers it... Thanks for the help all! |
Dick L
I have drilled out several B axles and pressed in bushings. Most of them are oblong holes. I bought bronze bushings at hardware store to fit the bolt and drilled out the hole to fit the bushing.
C in Concord
I agree, that is my plan for the front pivot. Just have to get the parts and build a support/splitting stand so I can get the axle off. Thanks again all!
Post Reply | |
