WC with 36" rear wheels????? |
Post Reply |
OldAC
Bronze Level Joined: 01 Feb 2018 Location: Rural Michigan Points: 168 |
Posted: 12 May 2022 at 1:43pm |
I may of happened upon the remains of a WC high crop. Has factory 36" rear wheels, and look just like the wheels on one the wide front high crops posted online. But this one is narrow front. Did they actually ever made a WC high that was narrow front? Or is this a mutt? There are no front wheels on it to get an idea if it sits level. Is the front bolster different then a regular narrow front WC? Were factory High crop tractors marked anywhere or stamped anywhere to differentiate from regular WC?
Edited by OldAC - 12 May 2022 at 1:49pm |
everett048
Orange Level Joined: 12 Sep 2009 Location: uk Points: 617 |
yes i have one also 900x36 and 450x 17 fronts on spokes also restored a 3 wheeler
With 36 rears.
Gary Burnett
Orange Level Access Joined: 11 Sep 2009 Location: Virginia Points: 2851 |
High clearance,high crops were totally different
Orange Level Access Joined: 12 Sep 2009 Points: 19477 |
I'm pretty sure WC's with factory 36 inch rear rubber had a slower ring & pinion to get the ground speeds back to what a regular WC was. Same gear set as an RC.
Richardmo
Orange Level Access Joined: 12 Sep 2009 Location: Rolla mo. Points: 1732 |
Look by the were the seat bracket is there should be numbers and and X in that location.
Those tractors have the slower gears in them. |
200Tom1
Orange Level Joined: 03 Jun 2019 Location: Iowa Points: 1124 |
Thompson "cane" Wc's had 36" rear tires. They usually were made to load sugar cane on rail cars or trucks. Is there any evidence of a big old loader on the tractor? They were usually mounted on the rear of tractor.
OldAC
So where exactly? Theres nothing other then the regular WC serial on the rear end pad. X designates the slow gears?
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7202 |
Sheridan Hansen had his on one of the Classic Tractor Fever videos. Apparently it was a factory high crop and few were made. He mentioned the gearing and 36" rear tires as the main differences between regular WCs
Richardmo
The # are not located in the serial #.
They had location had # and X located by the seat support on top of the rear end. I will try and get pictures next weekend and post.
Post Reply | |
