The Forum Parts and Services Unofficial Allis Store Tractor Shows Serial Numbers
WC with 36" rear wheels?????
OldAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldAC Quote  Post ReplyReply Direct Link To This Post Topic: WC with 36" rear wheels?????
    Posted: 12 May 2022 at 1:43pm
I may of happened upon the remains of a WC high crop.
Has factory 36" rear wheels, and look just like the wheels on one the wide front high crops posted online. But this one is narrow front.
Did they actually ever made a WC high that was narrow front? Or is this a mutt?   There are no front wheels on it to get an idea if it sits level.  Is the front bolster different then a regular narrow front WC?
Were factory High crop tractors marked anywhere or stamped anywhere to differentiate from regular WC?
Edited by OldAC - 12 May 2022 at 1:49pm
everett048 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2022 at 1:48pm
yes i have one also 900x36 and 450x 17 fronts on spokes also restored a 3 wheeler
With 36 rears.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2022 at 3:19pm
High clearance,high crops were totally different
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2022 at 3:30pm
I'm pretty sure WC's with factory 36 inch rear rubber had a slower ring & pinion to get the ground speeds back to what a regular WC was. Same gear set as an RC.
Richardmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2022 at 1:46pm
Look by the were the seat bracket is there should be numbers and and X in that location.
Those tractors have the slower gears in them.
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2022 at 5:38pm
Thompson "cane" Wc's had 36" rear tires. They usually were made to load sugar cane on rail cars or trucks. Is there any evidence of a big old loader on the tractor? They were usually mounted on the rear of tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldAC Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2022 at 8:52am
So where exactly? Theres nothing other then the regular WC serial on the rear end pad.
X designates the slow gears?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2022 at 8:52am
Sheridan Hansen had his on one of the Classic Tractor Fever videos.  Apparently it was a factory high crop and few were made.  He mentioned the gearing and 36" rear tires as the main differences between regular WCs
'49 G, '54 WD45, '55 CA, '57 WD45, '58 D14, '59 D14, '60 D14 '61 D15D, '66 D15II, '66 D21II, '67 D17IV, '67 D17IVD, '67 190XTD, '73 620, '76 185, '77 175, '85 6080
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2022 at 6:41am
The # are not located in the serial #.
They had location had # and X located by the seat support on top of the rear end.
I will try and get pictures next weekend and post.
