how to setup a transport valve on a wd45
johnny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote johnny Quote  Post ReplyReply Direct Link To This Post Topic: how to setup a transport valve on a wd45
    Posted: 21 Oct 2011 at 11:32pm
I got my transport valve put on the wd45 last nite and all the lines run.  Know how do I adjust it, I know there is only the knob but do I turn it all the way out or partially?
Any help is appreciated.   I will be using it at the plow day next saturday with the semi mounted 3 bottom plow.
thanks
johnny
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2011 at 8:09am
I run mine tractors all the way out for plowing and all the way in if I don't need the weight transfer and somewhere in the middle for more or less weight transfer. I'd start with it all the way out first and you can tell if it needs more or less weight on the tractor's rear wheels. If the front of the plow is coming out of the ground then the valve needs to go in more, if the hole plow is coming out of the ground then turn it out more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote johnny Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2011 at 5:05am
Thanks Don, I will give it a try tommorrow if the weather permits.
johnny
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2011 at 1:28pm
All the way out(open)!When T/B linkage is all adjusted correctly,the front of the plow will be lifted enough to keep you rolling with out lifting the back.An inch up on the quadrant is a good starting point for the lift lever.
