7040 transmission oil low
GregStremel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregStremel Quote  Post ReplyReply Direct Link To This Post Topic: 7040 transmission oil low
    Posted: 23 Sep 2019 at 5:37pm
After baling hay. I checked the dipstick under the seat. The oil was barely on the dipstick. It took almost 2 gallons to bring it to the full mark.
I don’t remember the last time I checked the dipstick. Never had a problem so didn’t check it. My bad. I know I checked at least in May.
There is no oil on the concrete floor. The underside of the tractor is dry. No obvious leaks.
I remember reading how oil can transfer to the rear end if a seal has gone bad. I have not yet drained and measured the rear end. The top sight glass is full. Is this seal I seem to remember in the transmission or would it be separating the oil pumps?
Any help is appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2019 at 8:20pm
Most times it is the seal in pump or seal on shaft that drives the pump. I always replace both.       MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregStremel Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2019 at 4:12pm
Thank you.
