Unofficial Allis Homepage
Pull switches for ceiling fans
Message Reverse Sort Order
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: Pull switches for ceiling fans
    Posted: 22 Oct 2017 at 2:03pm
Time for scaffold rental.
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2017 at 9:04am
I have to replace 2 ceiling fans one of these days. Been running non stop for the last 20 some years. One just stopped working very good. Both wired to the same switch so I just shut them off.
Bout 22 feet off the floor. Ain't quite figured out how I'm going to pull that off.
From my vantage point they look expensive.
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2017 at 7:46am
  Hey Steve(ILL),,,THANKS for thet dwg,,,!!!Now just waitin for the new switches to get in bout Tuesday.
  Hey Shameless and Jay,,,,,,the only'ist problem bout runnin down to store and gettin a new fan is,,,,,,them sons of beaches want ,,,,they want,,,real money,,,,Sheeesh,,,,
 The last guy just blinked at me when I mentioned an IOU,,,,,,,some people just ain't got no sense of humor these days,,,LOL
 But,,,I'll just keep on fixin these antiquated stuffs til they ain't no more parts for em,,thank you very much,,,,,,WinkWink
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2017 at 6:10am
I'm with DIYDave on buying a new fan.. The GREAT thing about the remote ones are SIMPLE wiring. Just need blk-wht and toy get fan AND light control ! Mine's about 15-20 years old , HD unit(Hampton Bay ??), 3 speed and variable dimming. direction is pullcord though. Never use it, always pushing air to the ground...summer or winter. yeah I _could_ modify that operation for $5....
If you're like me ,ladder time ain't fun time, especially with bifocals and itty bittty parts inside a moving object.....
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2017 at 5:31am
bypass the switches, wire direct, and use the light switch for on off?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2017 at 7:08pm
In the long run, might be better to upgrade to a new fan, that has a remote, to control it.  Them chains is always a breakin, around here...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2017 at 4:06pm
there are several versions of 3 speed fans...
the ones I deal with ( 20" box ones) have all been the same
power( black) from wall goes to switch then 3 wires (low-med-hi) go to 3 windings on the fan motor. There IS a capacitor as well..it's called the 'run ' capacitor. Needed to make sure the fan actually spins.
The neutral (white) wire of the power goes to the common of all 3 motor windings.
what you never ever want to do is change DIRECTION when the fan is RUNNING...bad things can happen then...
Jay
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2017 at 1:48pm
Go to Lowe's they carry replacement switches
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2017 at 1:09pm
Joe I sure hope you knowConfused more about this than the last guyEvil Smile asking that had to put his finger Winkin the socket and see if his hair would give off sparks to know if there was any juice.Thumbs UpThumbs Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2017 at 12:22pm
with the switch removed, connect BLACK to either the green , brown, or grey and ONE SPEED should work with the power turned back on.
Trump Is Not A Lib or Conserv, He's a "Pragmatist." (someone who is practical and focused on reaching a goal. Has a straightforward, matter-of-fact approach and doesn't let emotion distract him or her
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2017 at 12:20pm
the little black box is not really a capacitor. It is more like the resistor box on an auto blower motor circuit ....... there are 2-3 resistors inside that change the speed of the motor depending on which one of the 3 wires from the "speed switch" is energized.. I think you can find the common wire on the switch and connect to one of the "speed" wires and bypass the switch... If the fan then runs, the BLACK BOX is working... you can actually check all three speeds by connecting ONE WIRE at a time to the COMMON on the switch, bypassing it.
Edited by steve(ill) - 20 Oct 2017 at 12:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2017 at 10:41am
  Howdy,,,,Folks,,,,,OK,,now that we got the formalities out the way,,,,,,,lets get right to the subject,,Shall we,??Wink
  I gots to replace the pull switches on both of the ceilin fans in den and kitchen,,,funny how they both went out days apart???,,,
 Got one taken out and I kinda puzzled,, both fans are 3 speed.  This First pull switch has  4 wires and is wired to a square plastic box (capacitor?) that has 5 wires comin outa it. 3 of the wires from the square thingie go to the pull switch and other two go to the 115 from light on fan.  Clear as mud,,,???LOL
 The pull switch fell apart when I took it out so I figure it was the culprit and hopefully the square box is OK,,,??? I have no clue how to "test" thet little box,,,,,anybody,,??
 Got some new switches ordered as none to be fount in this little ole burg,,,,,Angry
