Stirring some dirt
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: Stirring some dirt
    Posted: 19 Sep 2020 at 4:28pm
Disced up some weeds with the D 15 today with my favorite son . Hope he'll post a picture soon .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2020 at 5:21pm
Still too wet to put a plow in the ground around here. Looking forward to seeing some pictures.
WeisAC2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WeisAC2 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2020 at 5:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2020 at 5:38pm
Looking good!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2020 at 5:51pm
Thanks Hubert . Our place is mostly sand , as long as we stay away from the branch we're good .
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2020 at 1:01pm
Old D 15 ran pretty well . Did blow some oil on the valve cover from the oil fill/vent . Guess the only cure for that is a engine rebuild ? Wonder if Seafoam or Restore oil additive would do anything ? Think engine compression is around 150 . Thanks !!
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2020 at 5:03pm
Looks like you're doing a good job of discing.
As to the "blowing oil", you might want to take the oil fill cap off and clean it well.  My CA was doing what you're describing but after a thorough cleaning, it was better.  FWIW.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2020 at 5:14pm
Thanks Brian . My fill cap is fairly new but I'll check it out .
