Steering gear grease instead of oil in b,c,ca? |
Post Reply |
JaredC(WI)
Silver Level Joined: 10 Apr 2019 Location: Birnamwood WI Points: 106 |
Posted: 15 May 2019 at 12:31pm |
Wondering who all is using grease instead of oil in their b,c,ca steering gear.
Looking back on old posts it seems like a common fix for leaks. Does the use of grease instead of oil effect steering in the winter? I would assume it would thicken up in cold temperatures. Jared |
DougS
Orange Level Joined: 03 Nov 2011 Location: Iowa Points: 2490 |
You are thinking gear grease, yes? I don't think it would hurt anything, but I'd stick with oil unless your seals are leaking.
Dakota Dave
Orange Level Joined: 12 Sep 2009 Location: ND Points: 3892 |
dont use grease itll never lube your gears. if you must you can use pouravble grease also known as corn head grease. it will lube your gears and stay in a fairly leaky front end. I havent noticed any diferant in the winter with corn head grease. my C had grease gun grease in it when I got it when i took it apart the gears were rusty and worn like it had been dry forever. the grease was all a ball at the top. the lower bearings were trash.
HoughMade
Orange Level Joined: 22 Sep 2017 Location: Valparaiso, IN Points: 690 |
I've been using 00 Cotton Picker grease. It's probably not as good as corn head grease in preventing leaks, but it's pouarble and seems to work OK.
1951 B
DougS
NGLI 00 or NGLI 000 grease are both pourable. I'd say use NGLI 000 in Wisconsin if you use the tractor in the winter. NGLI 00 would work fine in the summer. Normal grease as you'd usually find in a grease gun is NGLI 2 - three grades thicker than NGLI 00 and four grades thicker than NGLI 000.
Edited by DougS - 15 May 2019 at 1:06pm |
joelsplace
Silver Level Joined: 07 May 2019 Location: Northlake TX Points: 74 |
Tractor supply carries the 00 grease. At ours it was with the 3 point links and not in the normal oil section.
JaredC(WI)
Thanks for the info, guys. The CA leaks it's steering gear oil out pretty quick. Within a day or so of filling it it's on the floor.
Have been refilling it just before I use it since I got the tractor last year. Getting tired of wasting good oil. Next time I get to Fleet Farm here Ill look for that 000 corn head grease and give it a try. Maybe it'll save me the hassle of always refilling. Thanks again! |
Steve in NJ
Orange Level Access Joined: 12 Sep 2009 Location: Andover, NJ Points: 11502 |
I used grease gun grease in the steering box of my B 20 years ago. No problems with the box, and it steers fine even with the Henderson loader on it. I used an EP Moly grease..
Dick L
Orange Level Joined: 12 Sep 2009 Location: Edon Ohio Points: 5082 |
I use the same grease I use on all my farm equipment. I don't fill it and call it done. Every now and then I pump grease in until it come out around the seal that is already shot. Wipe the access off on your sleeve for your wife to get out if you don't carry a rag. It gives you something to talk about over supper. (:^D
TimCNY
Orange Level Joined: 15 Apr 2014 Location: Upstate NY Points: 1551 |
Somehow I think you forgot to put "ex-" before "wife" lol!!! Or soon-to-be-ex? That's funny.
I've been wondering the same thing. My WD45 adjustable has leaks, I've used grease, had the cover off and - not pretty. The manual calls for (going from memory so don't jump on me lol!) SAE 240 or 250... pretty much grease already. I haven't added fluid,, I've only greased it, am I causing harm by doing so? |
Dick L
I carry a rag! A bit sarcasm for those that have not figured how to fill the void. |
Post Reply | |
